Old 02-19-2006, 09:44 PM
saleen779 saleen779 is offline
saleen779 is off the scale
does anyone know the part number for the Mobil 1 oil filter? i picked one up at autozone and it looks small. i mean really small. it's about half the size of our expedition's filter. and the ford has a 4.6! i dont know if autozone messed up or if it's supposed to be that small.
H2 for life!
H2 for life!
Old 02-19-2006, 10:03 PM
ttt
H2 for life!
Old 02-19-2006, 10:55 PM
VTSTOMPER is off the scale
I thought the same thing when I bought mine - I was like - try again parts man...but it was right. You can cross it to find one that is longer if you want.
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 02-20-2006, 12:32 AM
thanks guys, i installed it and so far so good. i appreciate the quick replies.
H2 for life!
Old 02-20-2006, 12:34 AM
the k&n i got was miniture too, but it works fine as far as i know, or hope lol
Old 02-20-2006, 05:45 AM
I thought the same thing when I bought mine - I was like - try again parts man...but it was right. You can cross it to find one that is longer if you want. </div></BLOCKQUOTE><BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content"> FRAM ph3506, PH25
Walmart supertech/tech2000 ST3506
STP #3506
AC PF44, PF46(updated in 2003)
WIX 51042, 51045, 51258, 51364, 51522
NAPA 1042, 1045, 1258, 1364, 1522
Purolater PER123, PER124, PER33, PER4007, 14006
AMSOIL SDF32
BALDWIN B31
DEUTSCH D377
K&N 1007
MOBIL M1-107
PROTEC 167
CARQUEST 4006
Long version:
FRAM HP2, PH11, PH3429, PH3675*
AC PF58, PF59*
WIX 51049
NAPA 1049
Purolater PER5, L20123, L25228*
AMSOIL SDF64
MOBIL M1-206
K&N 2006
Bosch 3423
STP S3675 </div></BLOCKQUOTE>That should do it.
Old 02-20-2006, 03:19 PM
wow, thanks, yep i did buy the m1-107
H2 for life!
Old 02-26-2006, 09:15 PM
Ashley Ashley is offline
Ashley is off the scale
Hi
Whats the dimentions of this, in the UK the BOSCH part numbers do not show up the same as the USA ones (and Bosch cant get this right for trying).
Would be nice to have the thread size and pitch as well as the phyiscal dimentions (of the largest the H2 will handle)?
I assume it needs a bypass valve and backflow valve as well (either are good anyway)?
Many Thanks
Ashley
Many Thanks
Ashley
