Old 10-23-2003, 06:02 AM
TroysH2 TroysH2 is offline
TroysH2 is off the scale
I know this may have been covered already. But I noticed that the front passenger side tire rubs on the sway bar when making a left U-turn. Marks on both the tire and swaybar. Is there a solution for this.
thanks,
troy
thanks,
troy
Old 10-23-2003, 11:33 AM
JCJ JCJ is offline
JCJ is off the scale
Had same problem.
Add this to annoying-H2-things-thread...
Mechanic adjusted sway bar bolts/brackets.
Old 10-23-2003, 01:05 PM
Circuitguy
Normal. Dont know why but it is. BIG-C
White 03-H2-LUX
</a>
Old 10-23-2003, 01:35 PM
Circuitguy
Normal as it happens to most H2's. I have a 03 Denali that also rubs, this is also normal for this truck but it still should not happen. The problem is with the design it’s inherent in this vehicle. GM most likely knows it but why waist money to fix a problem when only .001% of owners are complaining. It bugs me too but I don't see it getting fixed real soon. BIG-C
White 03-H2-LUX
</a>
Old 10-23-2003, 01:40 PM
Circuitguy
Removing and replacing the sway bars will not change the alignment. I performed them a couple years ago as a fleet mechanic. BIG-C
White 03-H2-LUX
</a>
Old 10-23-2003, 05:40 PM
ANGELO D. ANGELO D. is offline
ANGELO D. is off the scale
WITH STOCK WHEELS THE FRONT TIRES WILL RUB WHEN TURNING. I TOOK CARE OF THIS PROBLEM BY GETTING RID OF STOCK WHEELS AND PUTTING ON NEW WHEELS WITH DIFFERENT OFFSET, NOW EVEN WITH 37IN TIRES I HAVE LOTS OF ROOM WHEN TURNING WITH NO CHANCE OF RUBBING.
Old 10-24-2003, 02:40 PM
PhilD, The wheels I went with are pro comp
exterrain, 17in/10in, I had these wheels powder coated black. You would have plenty of room with
13.50in tires because my 12.5in tires have over 4inches of clearance when tires are turned in all the way. good luck.
Old 10-24-2003, 03:21 PM
Tucson Beast
Hi ANGELO D
Do you have any pictures of your rim and tire setup to share
"It's what you learn, after you know it all, that counts - John Wooden
Old 10-24-2003, 04:15 PM
Patriot Patriot is offline
Patriot is off the scale
Not sure why but my 37" MTR's do not rub at all.
Old 10-24-2003, 05:29 PM
PICTURE OF MY H2 WITH PROCOMP WHEELS AND 37IN MTR.
Old 10-24-2003, 05:34 PM
ONE MORE TRY AT PICTURES, I TOOK ON HQ AND SEEMS TO BIG. LETS SEE
Old 10-24-2003, 06:06 PM
Another picture of approach
Old 10-30-2003, 02:45 PM
2slo4now 2slo4now is offline
2slo4now is off the scale
4 1/4 inch backspacing is the magic number for the aftermarket wheels. Running 37x13.5 M/T Baja Claws and they never rub. Never.
Dan from Alabama
Old 10-30-2003, 03:33 PM
Tucson Beast
Hey Dan
I like your tires - I am not an expert on tires/rims - a few quick questions:
Do they fit on stock rims?
Do you have to change any thing (speed setting-H2 clearance)?
What are Spacers and how do theyapply to your setup?
