Old 04-03-2005, 11:09 PM
LasVegas LasVegas is offline
LasVegas is off the scale
No...as a matter of fact some of their TSBs stipulate to use Permatex adhesive/sealer.
Jonahs
Old 04-03-2005, 11:43 PM
tower's Avatar
tower tower is offline
It's probably trolls. Does the fluid from the leaks taste like troll urine?
Old 04-04-2005, 12:12 AM
hummerNCO hummerNCO is offline
hummerNCO is off the scale
Drive through a big puddle and tell me if YOUR truck fills with water.
see my story
thank god we have ammo
Old 04-04-2005, 11:12 AM
VTSTOMPER is off the scale
hummerNCO...did you get it solved?
I have yet to leak test it today. I called the dealer, to help me brainstorm...not much help.
So we will see. I am going to do the door grommet if it is still leaking.
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 04-04-2005, 03:02 PM
still leaking.
So, I am looking at the inside of the door frame now. The two bolts that are attached to the door stop hardware (just above the wiring gromet) Seemed loose...so I tightened them down a bit.
I then ran the hose for about 1hr on top of the roof. The water was only going though the channel at the top, and not hitting the sunroof at all as I did in the other tests. It did leak, but not nearly as much. I then took off the door gromet on the Hummer side, not the door, and filled the inner lip with RTV, put it back on and sealed around that with RTV. For extra measure, I put RTV around the bracket I tightened in the first place. Now to let it set, and I will try it all over again.
Old 04-04-2005, 03:19 PM
pic
Old 04-04-2005, 05:06 PM
pic </div></BLOCKQUOTE>Sounds like you're making progress. At least you've isolated the problem. You may have to look at the seals under the roof rack channel.
Jonahs
Old 04-04-2005, 05:21 PM
Jonahs,
You rock! Thank you for your ongoing help with this. I was wondering about the seals under there. I will cross that bridge tonight if I have to. I am hoping I have it licked now. Tonight I will have another leak test to see if what I did at noon took care of it.
Old 04-04-2005, 05:45 PM
One last suggestion on testing for leaks. START AT THE BOTTOM! Then work your way up slowly. Give it time to start appearing so don't get in a hurry. By doing that you'll absolutely isolate the area i.e. below a certain point. Then you can quickly zero in on the culprit.
Jonahs
Old 04-04-2005, 06:10 PM
This is true. My step ladder has been holding the hose as I run around to find the leaks.
Old 04-04-2005, 06:33 PM
Hummertech is off the scale
If those door grommet seals are not tightly
sealed it will pour water in. Take a good look at that, especially if the leak started after someone was messing with it for some reason, (running wires, etc..)
Old 04-04-2005, 06:40 PM
Hummertech,
Thanks for the advice. I think that is what it was...yet there has not been anyone running wires. I think the factory fit is not that great seeing that GM made all the water run right down through there. I had an ice storm here about a month ago..and the area between the frame and door had a large build up of ice...it was pretty wild.
I am just waiting to get out of work to be sure. Then i can focas on getting everything dry and back together.
Old 04-04-2005, 08:39 PM
Fixed. It was the door gromet. I am happy that is over.
Old 04-04-2005, 08:48 PM
Fixed. It was the door gromet. I am happy that is over. </div></BLOCKQUOTE>Well thank God for that Vtstomper! I know that kind of thing is a pain in the butt. Good for you hanging in there to find it. Now check the OTHER door!
Jonahs
Old 04-04-2005, 08:55 PM
just did the other door...gotta be safe!
Old 04-05-2005, 12:56 PM
TXSUT's Avatar
TXSUT TXSUT is offline
Glad you got it figured out, J; and thanks for taking us through it with you in case it happens to one of us.
-Pete
Old 04-05-2005, 05:58 PM
No prob Pete! I was so bummed when I heard that water soshing back and forth. Glad it's over.
Old 04-06-2005, 06:11 AM
hummerNCO...did you get it solved? </div></BLOCKQUOTE>
I took my truck in this morning to have the pad replaced and the carpet cleaned. They are going to look at the floor when the carpet is out to see if there is any other sign of leakage there. After reading your posts I am going to ask them to seal the door grommet for good measure. I値l be puddle hunting soon.
Old 04-07-2005, 09:20 PM
I hear that there is a grommet that can leak near or above brake pedal or fuel pedal. Not the one in the floor. Hummer told me about that when I asked about my leak.
Old 04-08-2005, 04:46 AM
I picked up my truck this afternoon. Cerritos HUMMER re-sealed the floor plug, sealed some seam along the door pillar, removed the AC box and sealed something around there (then had to recharge the AC), and replaced the rubber seal around the door. They say it was thoroughly checked for leaks with the carpet and pad out and they seem confidant that it should not leak. Unfortunately they did not seal that rubber boot around the wires in the door pillar even though I asked them if they could. I told them yesterday that I had heard of others finding that to be the source of their problem so I thought they might put some sealant there for good measure, but no.
I did not find the foam under the pedals to be wet so I did not think the water was coming from the firewall area and they said the same thing. So hopefully the grommet up there isn稚 the source.
I知 heading to Las Vegas this weekend, then up to Tahoe. Seems unlikely that I値l find any good puddles out there between Death Valley and the bombing ranges. I値l find some somewhere though and we値l see.
