Old 11-09-2005, 11:10 PM
WhiteH3 WhiteH3 is offline
WhiteH3 is off the scale
Anyone experience squeaks and rattles under the hood and behind the dash(probably near the radio), when outside temps cool down? Suggestions/solutions/advice?
Favorite Off Road Trips: Death Valley & Joshua Tree
Off Roaded Vehicles: H2, Yukon, Suburban, Jeep Wrangler & Unlimited
Old 11-09-2005, 11:40 PM
JV1's Avatar
JV1 JV1 is offline
JV1 is off the scale
Nope nothing at 800 miles (knocking on wood).....
06 H3, Red, Automatic, Adventure Package, Monsoon Radio, Trailer Hitch, Brush Guard, Side Steps, Roof Rails with:
Cracked Trim, Transfer Case with almost no fluid in it from the factory, Bad windshield washer pump, Bad Jack, CD eating stereo. But GM tells me the quality is as good as anyone????
Old 11-09-2005, 11:56 PM
4ophenia 4ophenia is offline
4ophenia is off the scale
Not under hood nor behind dash, but a soft rattle coming from front passenger side. Happens only when I'm driving over bumpy surface. Sounds like something inside the front passenger door is hitting against something. I swung the door from side to side but could not reproduce sound. Could be from rapid up and down movement.
Having the dealer check it out next time I'm due for service.
2006 H3 Adventure/ Yellow/ Ebony/ 5-speed/ Black Brush Guard/ Black Tubular Steps/ Mud Flaps/ Black Crossbows/ Trailer Pkg/ Monsoon/Hadley Chrome Dual Air Horn
Repressed as a child, but no more ....
Old 11-10-2005, 05:02 AM
hummerdonthurtem hummerdonthurtem is offline
hummerdonthurtem is off the scale
Once in a while I hear rattling from the center A/C vents or under the dash when I am moving at a crawl.
Also, when I am accelerating hard (above 2400 RPM) I sometimes hear rattling from under the engine. I think there is a service bulletin for this one. I need to check with the dealer the next time I get my rig serviced.
Black, Lux, Off-road Package, chrome brush, black step bar, mud flaps
Old 11-10-2005, 09:09 PM
H3 Hummer's Avatar
H3 Hummer is off the scale
Not sure if this is your problem but you can check or it is good information for all.
Next to the firewall are some long steel tubes that are held in place by plastic connectors. The tube just pops into them. Well if it pops out it will rattle and sound horrible when going over bumps. I took my truck in and they didn't find anything but I found this and now no more issues.
Old 11-21-2005, 03:07 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by H3 Hummer:
Next to the firewall are some long steel tubes that are held in place by plastic connectors. The tube just pops into them. Well if it pops out it will rattle and sound horrible when going over bumps. I took my truck in and they didn't find anything but I found this and now no more issues. </div></BLOCKQUOTE>
I also had to pop the steel tubing back into some of the connectors. I still had some minor rattling at high RPMs. The same steel tubing was also rubbing against the plastic housing on the firewall that surrounds the A/C tubes. So I bent the steel tubing away from the plastic housing and now all the rattling/vibration has disappeared.
