Old 03-14-2005, 12:16 AM
vip808 vip808 is offline
vip808 is off the scale
does anyone know if it would be possible to replace the stock shifter with a Hurst Pistol-grip shifter?
http://store.summitracing.com/largei...rt=HUU-3162030
Old 03-14-2005, 04:18 AM
Black 05 Black 05 is offline
Black 05 is off the scale
No it will not bolt in, But i can custom make it work for you.
Old 03-14-2005, 05:38 AM
I may be interested Black 05 if with several of us maybe We could get the price reasonable.
let me know if you end up doing it or a prototype so I can see what it will look like as finsihed product. You may already have idea as far as cost if so what would cost be?
TAZ
Old 03-15-2005, 01:11 AM
I made this one
Old 03-17-2005, 02:46 AM
Black 05
What do You think the cost of the Hurst pistol grip chromed or ultra polished billet with a blue top mounted led light shift button will be?
TAZ
Old 03-17-2005, 03:28 AM
Well I haven't looked at it that closely. When I did mine I didn't want to remove the factory base. The shifter I made slides over the factory 1/2". There is a 1/4" plastic shaft that goes in the middle of the 1/2" rod. I had to gut out the inside of the "T" handle so I could make a mechanism to work inside the shifter. The shifter you want is a little simpler to make because your button doesn't have to be 90 degrees. I would need the Hurst shifter to modify. Only need the shifter itself. I wouldn't use the base or hardware at all. I don't know if you can just buy the handle. I charge $75.00/hr. and I am sure it would be a days job. I would fit everything to my H2 and take photos before I would ship.
Let me know what you want to do. There is a small allen head set screw on the shaft of the factory shifter if you want to remove it and take a look or I can take mine off and send you photos.
Old 03-19-2005, 07:04 PM
DH22G's Avatar
DH22G DH22G is offline
DH22G is an unknown quantity at this point
how tall is your shifter? it looks HUGE... and if its not that tall becasue i would like it to be a little shorter maybe around teh stock height or actually maybe shorter. How much would it be for the shifter ready to go?
- DH22G
David
2007 Acura TL Type S
Old 03-19-2005, 09:52 PM
Its the same height as the stock shifter. I am going to lower it 3/4". Its hard to say what it would cost. I would say $600.00-$700.00 for the of work, It would take a day to make.
