Old 09-25-2005, 02:00 PM
FiremanJay's Avatar
FiremanJay FiremanJay is offline
FiremanJay is an unknown quantity at this point
Cool
I did 100% of the install myself. Got the set up from www.jpcustoms.com took them 3 days to get it to my front door then spent a sat while i was working at the firehouse to do the install. very simple and easy, JP customs sent detailed intructions on dash removal install the works. Prior to getting into Harleys and working at a dealership part time i did stereo installs. So it was fairly easy. Just a few basic tools and read the instructions.
03 Black Lux
03 Custom Chopper
96 Road King
82 Vette
Old 09-25-2005, 03:16 PM
Sportsdude's Avatar
Sportsdude Sportsdude is offline
Sportsdude is off the scale
$395.00 for PAC GM2 video adaptor for touch screen navigation. From reading the install instruction, it said to get relay and something else before installing. Can't believe that the kit didn't come with the necessary items to complete the install, especially costing $395.00
2005 H2 SUV (Yellow)
2003 Vert Supercharged
Old 09-25-2005, 03:27 PM
FiremanJay's Avatar
i didnt hook up any relay to the video adapter. and it works just great. i did use a relay and pre ran the wires for the back up cam placed them behind my glove box. so when install it i wont have to take apart dash. relay was used to allow reverse to activate screen then switch to turn on while driving. the pic of the adapter doesnt show the latest unit the one you would receive has 2 video inputs.for the unit you do have to take the top off of the NAV unit and install the new ribbon wire, but it is very simple and the instructions are easy to understand.
03 Black Lux
03 Custom Chopper
96 Road King
82 Vette
Old 09-26-2005, 08:35 AM
rodster rodster is offline
rodster is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by FiremanJay:
Well my 6 disc changer only works for cd's but you could get a dvd changer that will do the same job as an in dash unit.
You could place a dvd player in the center console, you will need to make sure that it will work mounted verically as well as horizontal. You will need to modify the inside of the center console. The NAV/DVD dash unit only reads data DVD's and i keep my NAV disc in there all the time. It will play cd's i understand but i never used it for that due to the 6 disc changer. </div></BLOCKQUOTE>
Thanks for the follow-up.
My '05 came with the center console vertically mounted DVD unit and Visualogic head rests. I've been considering removing the existing player and replacing it with a multi-disc unit under the rear seats. I sure would like to have the storage area in the console and swapping dics while driving with the present setup isn't exactly convenient. Or safe.
I have Framecam's Hitchcam mounted on the rear spare. It'll help with backing up to a trailer but it does have its limits. The line of sight from the cam to the hitch receiver is blocked by the bottom of the tire. It'll get you close, maybe close enough with a little practice.
\'05 SUT
Old 09-27-2005, 09:16 AM
FiremanJay's Avatar
Thanks for the infoon the cam.
do you know what unit you might go with for the DVD changer? i hear Pioneer makes a nice one.
03 Black Lux
03 Custom Chopper
96 Road King
82 Vette
Old 09-27-2005, 09:22 AM
do you know what unit you might go with for the DVD changer? i hear Pioneer makes a nice one. </div></BLOCKQUOTE>
Haven't figured that out yet.
\'05 SUT
Old 09-27-2005, 05:54 PM
Sportsdude's Avatar
Rodster, Are you satisfy with the frame cam? Does it work at night?
Fireman Jay, Thank you for the info. I bought the CD changer but may wait to get the rest of the gadgets and try to do the install. Would you happen to have the install instruction that you can email me a copy? Thank you
Old 09-27-2005, 10:27 PM
FiremanJay's Avatar
I'll look and if i can find them i will scan them for you.
03 Black Lux
03 Custom Chopper
96 Road King
82 Vette
Old 09-27-2005, 10:50 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Sportsdude:
Rodster, Are you satisfy with the frame cam? Does it work at night? </div></BLOCKQUOTE>
Yes and yes.
If I had to do it again, I'd buy just the frame cam and not the monitor then pipe the video into the nav unit display.
If you have the rear tire carrier with the plastic tag holder, you'll need to cut the plastic so the camera can tilt down. If you mount the frame with the camera on top it blocks the tag light.
\'05 SUT
Old 09-28-2005, 10:41 AM
VTSTOMPER is off the scale
Damn, your truck almost looks white!
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 09-29-2005, 03:55 AM
Stellar Stellar is offline
Stellar is off the scale
Nice set up. Mine is somewhat similar but my rear camera only turns on when I put it in reverse.
2005 Black LUX
37x13.50R17 Toyo MT
Torsion keys. 2" rear coil spacers
2" wheel spacers
In Tune I2, Air Raid Filter, Air Raid MIT, throttle body bypass, straight pipe exhaust
Cognito UCAs. Kryptonite UCA ball joints. Kryptonite tie rods. Kryptonite death grip Idler. Moog HD pitman.
5.13 gears. E-locker front
Bilstein stabilizer
Old 09-29-2005, 11:01 PM
JHALL JHALL is offline
JHALL is off the scale
i have installed the tsn in my 03 and am waunting to get the xm as well....what all do i need and how hard is it to put in?....do i have to splice into the harness going into the back of the nav unit or what?....thanks for all the info in advance!!..and if anybody has the gm part #'s for the cd changer and the xm along with how to instructions that would be much appriciated!!....
Old 10-01-2005, 03:04 AM
Cotaboda Cotaboda is offline
Cotaboda is off the scale
I love your setup. I am going to try to duplicate it except I will find a different place for DVD player. What modifications were made to the wiring allowing the passenger to input a destination while the car is in motion.
Old 10-01-2005, 08:48 AM
Sportsdude's Avatar
Anyone tried the universal headrest video rather than the $2000 plus version for the H2? Any thoughts on the overhead monitors?
Old 10-01-2005, 10:43 AM
FiremanJay's Avatar
the onloy splicing i had to do was at the wire harness to the speedo. i spliced a wire from the vss to a switch then to the back of the head unit. very simple operation. now my passenger can input info while the vehicle is in motion.
Because as we all know the driver shouldnt do that cause he may have an accident.........LOL
03 Black Lux
03 Custom Chopper
96 Road King
82 Vette
Old 10-01-2005, 10:44 AM
FiremanJay's Avatar
jhall you got mail.
sportsdude do you have a link to these headrests.
03 Black Lux
03 Custom Chopper
96 Road King
82 Vette
Old 10-01-2005, 03:12 PM
Sportsdude's Avatar
FiremanJay, Here's one that JP sells: http://www.jpcustoms.com/store/customer/product.php?pro...16689&cat=302&page=1
I've seen some universal types but don't know if the headrest will match among other things. One question please with the GM PAC. Does it still only have one video input or is there a newer version than the one posted on their web site?
Old 10-01-2005, 04:41 PM
FiremanJay's Avatar
thanks sportsdude the new pac-audio unit that i received from jp customs has 2 video inputs i use input 1 for the dvd and input 2 will be used for the rear cam i understand that when i either put my vehicle in reverse or turn the switch on the pac-audio unit will default to line 2.
03 Black Lux
03 Custom Chopper
96 Road King
82 Vette
