Go Back   Hummer Forums by Elcova > General Hummer Talk > Off-Roading
Old 02-23-2003, 05:19 PM
Sandra Sandra is offline
Sandra is off the scale
We are looking at March 16th
Old 02-23-2003, 09:23 PM
brianfriend brianfriend is offline
brianfriend is off the scale
Sandra,
That is a Sunday I think yes? My truck should be good to go by then for the most part. I may still be minus a cv joint but I should still be ok depending on the trail. I will post in the trails section.
If it can break it can be fixed.
Old 02-23-2003, 10:23 PM
Great, we have Adam and Alec that always get together and we are trying to grow the Colorado H2 Club.
Old 02-23-2003, 11:19 PM
cool...I posted in the local events thread. I am assuming that is where trips are organized?
Old 09-09-2003, 01:56 AM
SuperPoser SuperPoser is offline
SuperPoser is off the scale
chains are good if you make sure they are not rusting and have cracks and junk like that...
chains are not safe if you will be jerking...
straps work well too (I mostly use straps)
I get super high strength tractor straps (usually from tractor supply co.)
of course I have a taco and a runner, so my rigs are a lot lighter than your h2's...
so you may need something bigger?
(I usually get the 20,000lb straps)
inspect the straps before you go wheeling...
if there is fraying or any kind of wear... burn it now so you don't use it later!
also, keep them out of the sun...
the sun will rot the straps!
http://www.eng.ysu.edu/~melliott/hobbies.htm
