Old 04-12-2006, 01:28 AM
black06atx black06atx is offline
black06atx is off the scale
will these rims work on my h3, 16x10 Size 6x5.5 Bolt Pattern 4" Back Spacing. just asking because im about to get it.
Old 04-12-2006, 03:52 AM
I'm thinking they'll be too wide and rub pretty bad. The stockers are 7.5" wide w/ 5" backspacing IIRC. You should probably look at 8" or 9" rims.
I could be wrong about the stock specs though.
Old 04-12-2006, 11:17 AM
agreed go with a 9" or narrower wheel .
Old 04-12-2006, 01:05 PM
okay, so is the 4 inch back spacing good.
Old 04-12-2006, 05:13 PM
I know on the 8" rims the BS is usually 4.5". So I guess with the 9" rim, 4" BS might be okay.
Which tires are you getting?
Old 04-12-2006, 09:33 PM
well i called 4 wheel parts and told them that i was looking for some steel rims, told them i was looking for a 16 and they said these would fit
16x8 Size 6x5.5 Bolt Pattern 4.25" backspacing
what do you think? will these work, i thinking about just buying one and testing it out. hell, its only 74.99 a wheel.
this is what they look like,
http://www.4wheelparts.com/4wp/products/productLine.asp...ame=WHEELS&man=TECH#
reason im looking at these, is because a friend of mine has some super swampers lying around and they are 35's.
Old 04-12-2006, 09:56 PM
Should work. The tires are gonna stick out a bit. Hope you don't mind mud on your door handles.
And of course, you know you are required by Elcova law to post pics once they're mounted.
Old 04-13-2006, 02:34 AM
whats the widest tire i can fit on a 16x8.
Old 04-13-2006, 04:10 AM
Most of the tire sites will show a minimum rim width in the specs.
