Old 11-04-2005, 06:04 PM
michcsi9 michcsi9 is offline
michcsi9 is off the scale
I just purchaced an H3 and my dad was thinking of buying an H1 but he was wondering what the towing capacity on it is. That is something he needs for work and i figured yall were the best people to ask!!! Thanks for your help.
Old 11-04-2005, 06:12 PM
ckhagman ckhagman is offline
ckhagman is off the scale
there is a topic on this very subject on http://www.hummernetworkforums.com
http://www.penta-nut.com
The Most Sirius Off-Road Vehicle
Old 11-04-2005, 07:03 PM
Thanks for that info, it wasn't as much as he was hoping for but we are going to take a closer look at them.
Old 02-03-2006, 02:26 AM
Vicious Vicious is offline
Vicious is off the scale
I was wondering this same thing, but that link wouldn't work for me. Does the independent rear suspension make it difficult to to tow a trailer?
I have a 24' trailer I tow my dragster in & I'm considering an H1. Any personal experiences with pulling a similar load?
Old 02-03-2006, 08:40 AM
ssgharkness020147's Avatar
How far do you need to tow it, and how much does it weigh?
1997.5 Black Slantback
The Sole Remaining God Father
-007=
Old 02-03-2006, 05:50 PM
Michael A's Avatar
Michael A Michael A is offline
Michael A is off the scale
I tow a 20' Maclander steel deck trailer with a 4200 lb Jeep (and an extra set of sand tires, tools,parts, etc..) on it and have had no problems with it swaying etc. The total loaded weight is around 7200 lbs. I'm not even using a weight dist. hitch or sway control, but I am staying within the recommended tounge weight, and the trailer has brakes on all four wheels.
I've towed it out west as well as to North Carolina (via I-77 through the mountains) and had no problems, but I would switch to a good synthetic trans oil, and don't use overdrive if you by one with the 4L80E trans.
My 2 cents: I can't speak for the new alpha model, but if your idea of towing is going over 60 MPH with a heavy trailer I'd just go get a new F350 and ride in more comfort with a fatter wallet.
01' H1 HMCS
Old 02-03-2006, 09:44 PM
I tow it about 45 miles each way to the track. I'm not sure of the weight, but the dragster weighs 1,600 lbs plus the steel contruction of the trailer (aluminum body), tools, pit bike etc. Probably around 6,000lbs.
As far as the F350 comment that was my intention, but if I'm gonna spend $40k why not pick up a '01 or'02 H1 & be happier with my truck.
Old 02-03-2006, 09:55 PM
The H1 should be fine to tow that distance.
-007=
Old 02-04-2006, 02:24 AM
Michael A's Avatar
I understand, I was going to replace mine with a new F350 (warranty, cheaper parts) this year but just didn't have the heart to go through with it.
45 miles with 6,000lbs. no problem. Mine regularly makes the round trip to the U.P.(upper Michigan) at 400+ miles round trip.
01' H1 HMCS
Old 02-16-2006, 05:53 PM
Winneconne Winneconne is offline
Winneconne is off the scale
I had a 2003 H2 since new, and I've always been critical of the towing capacity. I purchased a 03 H1 and I have forgot my complaints.
