Old 02-17-2006, 05:33 PM
Hummers4LIFE Hummers4LIFE is offline
Hummers4LIFE is off the scale
Did anyone hear about the new DUB-AIR CAI for the H2? I am thinking about getting it. Who already has one installed and how do you like it?
www.dub-air.com
www.dub-air.com
Old 02-17-2006, 05:37 PM
makes no sense
Old 02-17-2006, 05:48 PM
drmiles's Avatar
drmiles drmiles is offline
drmiles is off the scale
In theroy adding the High flow filter and isolating fron the engine heat is a good idea. In reality the stock airbox provides adequate flow (unless you Supercharge) and the stock box isolates the intake air from the engine heat.
Old 02-17-2006, 06:04 PM
Klaus's Avatar
Klaus Klaus is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by drmiles:
(unless you Supercharge) </div></BLOCKQUOTE>
Can't agree with that... My truck is supercharged and runs just fine with the stock filter/airbox.
Old 02-17-2006, 06:25 PM
Mr. I - Man's Avatar
DUB = Ghetto marketed crap!!
Old 02-17-2006, 06:26 PM
Bling Bling ya'll!
The dual-purpose intake tube doubles as one hella fine crack pipe!
Old 02-17-2006, 06:37 PM
shipbldr shipbldr is offline
shipbldr is off the scale
Makes perfect sense... make it for $10, sell it for $400... very profitable.
Oh!!! You meant it was supposed to make a big difference & work!!
(Sorry)
Old 02-17-2006, 06:55 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Hummers4LIFE:
www.dub-air.com </div></BLOCKQUOTE>See this area of concern:
Information on airboxes
Old 02-17-2006, 07:02 PM
Fubar's Avatar
Fubar Fubar is offline
x2 exactly
Is there a cover that goes over the Dub-Aior filter box?
If not, it will actually increase intake temp, as it obviously wouldn't fully seal against the hood and would be taking in the very hot air from under the engine compartment. Kind of a Hot Air Induction system
Have you sold many to H2 owners yet? </div></BLOCKQUOTE>
Old 02-17-2006, 07:35 PM
drmiles's Avatar
Does it??? Are you sure your putting out the full 480hp it could? Maybe maybe not. If your supercharger is restricted your not getting the most out of it. Check with the Manufacture, do they recommend a high flow air filter.
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Klaus:
Can't agree with that... My truck is supercharged and runs just fine with the stock filter/airbox. </div></BLOCKQUOTE>
Old 02-17-2006, 07:36 PM
drmiles's Avatar
If it does not seal from the engine heat it will reduce power by increasing the air temp entering the throttle body.
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Fubar:
x2 exactly
Have you sold many to H2 owners yet? </div></BLOCKQUOTE> </div></BLOCKQUOTE>
Old 02-17-2006, 07:38 PM
drmiles's Avatar
Call Ed Langer at Magnumson for more info.
Can't agree with that... My truck is supercharged and runs just fine with the stock filter/airbox. </div></BLOCKQUOTE> </div></BLOCKQUOTE>
Old 02-17-2006, 07:49 PM
Klaus's Avatar
From the installation manual:
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Our Magna Charger kits are designed for stock engines, with stock components, in good mechanical condition only.
http://www.magnacharger.com/pdf/manual-HummerH2.pdf
</div></BLOCKQUOTE>
Old 02-17-2006, 08:05 PM
H3HUMVEE's Avatar
H3HUMVEE H3HUMVEE is offline
H3HUMVEE is off the scale
I am thinking about getting it. </div></BLOCKQUOTE> Aren't you with Dub Air? Why would you have to think about getting your own product? </div></BLOCKQUOTE>
Owned </div></BLOCKQUOTE>
LMFAO ...
_. __________
H /__________\
3[O][][][][][][O]
Old 02-17-2006, 08:17 PM
drmiles's Avatar
Doesn't mean your getting the most out of it you could.!
Old 02-17-2006, 08:19 PM
drmiles's Avatar
I built an adapter that mounts the K&N cone filter inside the stock airbox. Better flow (probably only slightly) and maintains the separation from the engine heat.
