Old 02-20-2006, 04:53 PM
fourfourto's Avatar
The H3 sat from friday 8pm till today monday at 11 am battery was dead?. I did wash it on saturday and water froze up after wash(had to get rid of the salt from the roads).After I put on charger (15 minutes)It started . the drivers window didnt work the locks would only work the drivers door and the on off switch on the door didnt do nothing.also auto start didnt work after shutting off and restarting.Checked fuses all ok. I did brake a clip on the plastic removing cover(cold).Ran it for 15 to 20 minutes everything is working properly now.
I called hummer and made an appointment for tuesday 2/28 At that time I was getting a oil change,tire rotation , inspect the rear washer pump,and install passanger side roof plastic( I ordered last oil change)They said if I have a problem with the new one in march /april they will install complete updated rails on both sides.Also on tuesday the will check battery/ system.Also said if it dont start tommorow morning bring it in.Also they said they would have to look at fuse cover as it might not be covered under warranty.If it starts up over the next few days Ill wait till tuesday.Im going on a road trip upstate on thursday and wont be back till sunday (hopfully I get some good pics in)I guess if I have a problem upstate I will call onstar.
Any ideas why battery went dead. The eclipse system and remote start were installed 2 months ago and It has sat for 2 or 3 days in that time
also its been longer on my airhorn set up about 4 months and a month with the 12 volt fridge,that I used a relay for and shuts off with the key using a Rap circut.Nothing seems to be on or running with the H3 off.
fourfourto's Avatar
Old 02-20-2006, 06:52 PM
fourfourto's Avatar
My wife took it to work around noon and it just started fine.Hopefully it will be fine in the morning.
Old 02-21-2006, 01:10 AM
442 sorry to hear about that , seems like " a Ghost in the machine " hope they find something when in for service .
Old 02-21-2006, 01:11 AM
the 12 volt fridge ? you didant leave it on ?
Old 02-21-2006, 11:54 AM
fourfourto's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">NEOCON1
Posted Feb 20, 10:11 PM
the 12 volt fridge ? you didant leave it on ? </div></BLOCKQUOTE>
I have the fridge running through a relay off a RAP circuit when keys out and you open door it shuts off.
Old 02-21-2006, 11:59 AM
Disnydad's Avatar
Disnydad Disnydad is offline
Disnydad is off the scale
Sounds like when there was a round of defective batteries in the Cadillacs last year. Bad cell.
2006 H3
2004 Cadillac SRX
Old 02-21-2006, 12:25 PM
fourfourto's Avatar
Thats what Im hope's the problem.It just started easily sitting 14 hours.I will be using it every day till next tuesday so We will see.
Old 02-21-2006, 07:42 PM
One of the top ten hits on the GM assistance center...dead batteries. Per my neighbor, who works for the Lexus assistance center in Auburn Hills, MI, bad batteries are in their top ten list too.
Normally, these happen in hot climates more than cold. In cold, the battery goes dead and if really dead a cell goes bad. In hot climates, the cells just go dead without losing the charge first as in a cold climate.
Old 02-21-2006, 08:26 PM
fourfourto's Avatar
Im hope it the battery .
Old 02-21-2006, 09:30 PM
wannabeH3's Avatar
u prolly left your radio on while u were washin it.. that amp will kill a battery in a day
(with insurance)
Old 02-21-2006, 09:35 PM
Probably just a crappy batt 442, I wouldn't stress until it happens a 2nd or 3rd time.
Old 02-21-2006, 09:55 PM
fourfourto's Avatar
I think I read it was only 550 cranking amps.I put a 1000 cranking amps 900 cold cranking amps in the 442 with 18 wheeler thick cables( my brother works on the rigs for fed ex he made me + & - cables using heavy gauge wire) starter cranks and starts up after sitting a month or two.
In a couple years ill upgrade the battery(maybee sooner)
Old 02-21-2006, 10:13 PM
I'll be replacing mine with an Optima Gel, so that when I roll it, I won't spill acid on the inside of the hood.
Old 02-21-2006, 10:29 PM
fourfourto's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">I'll be replacing mine with an Optima Gel, so that when I roll it, I won't spill acid on the inside of the hood. </div></BLOCKQUOTE>
I was thinking the same thing Optima Gel
Old 02-22-2006, 01:20 PM
I have put Optima Gels in a couple of my vehicles and they are by far the best batteries I have ever had.
Old 02-22-2006, 06:52 PM
fourfourto's Avatar
Well wife just called at work : this morning it started fine.At lunch, she started it and had it run about 5 minutes shut off while watching dvd for about 30 minutes she goes to roll down window and it seemed slow so she goes to start it and click click click battery dead again.Ill go pick her up after work and jump it.I called dealer, im bringing it in tommorrow morning to get it look at .Hopefully its just the battery and not a drain on something factory or aftermarket.I was planning to go upstate tommorow till sunday .Hope they figure it out and dont tell me its a accessory.
We will see.
Old 02-22-2006, 07:53 PM
I have put Optima Gels in a couple of my vehicles and they are by far the best batteries I have ever had. </div></BLOCKQUOTE>
And rather than use jumper cables, if the posts align, you can literally turn it upside down, touch posts with a dead battery, and the vehicle will start.
Old 02-22-2006, 07:55 PM
wannabeH3's Avatar
well you said u got dvd's prolly got a bad install causing a power drain or some ****.. better have the installer take a look at it.
(with insurance)
Old 02-22-2006, 08:09 PM
fourfourto's Avatar
The install was done 2 months ago Im hoping its not it seems to work properly and I used a good installer.I see what happens tommorow at dealer.
I just called on star the said they will have someone there at 7:30 when my wife gets off work.Ill let them do it its a 1/2 hour away.
