Old 09-05-2005, 03:03 AM
WZOMBIE WZOMBIE is offline
WZOMBIE is off the scale
I was wondering which model worked out the best for mounting and had easy access on the dash area? Does anyone have the plug and play version?
Hey Now!
Hey Now!
Old 09-05-2005, 05:57 AM
brndray brndray is offline
brndray is off the scale
I have the sportster replay, it has a suction cup mount that works good in the cup holder. This model aso has a remote in case you do want to mount it on the windshield.
Old 09-06-2005, 03:48 PM
guyzilla guyzilla is offline
guyzilla is off the scale
after a long search i found the following to be the best:
1. use the ash tray/coin holder that came with your h2 (can buy for $40 if you don't have one).
2. get a sirius sportster and attach it to the top of the cupholder by predrilling 4 small holes in the lid.
3. put the coin holder in the cupholder closest to you and you can change stations without moving your arm since it is so close.
4. stash the extra cords from power and antenna in the cupholder. the hinged cupholder lid works well for this.
5. run the antenna wire all the way to the back. it is very simple to do. takes about 15 minutes to install.
