Old 11-01-2005, 12:43 AM
CslRkH2's Avatar
CslRkH2 CslRkH2 is offline
Any problem wheelin on a tire that's been plugged? I picked up a nail this weekend and was curious if the tire can be trusted anymore. Thoughts?
CslRkH2's Avatar
Old 11-01-2005, 01:01 AM
Beastmaster's Avatar
Beastmaster is off the scale
Where did you pick it up?
Tread area - no problem. I'd trust it if it's patched properly.
Sidewall - less so.
M101A2 Trailer
Old 11-01-2005, 01:02 AM
NO! You should upgrade to TOYOS! NOW!
You should be OK, Why don't you just swap out your spare and throw that other one on the back?
I'm not sure aboout airing down with the plug though.
Old 11-01-2005, 01:04 AM
CslRkH2's Avatar
It was between lugs straight in near the side wall. At first Disc Tire wasn't sure they could fix it because it was so close the the side, but they were able to.
I don't know jack about tire repair. So when I air down it won't compromise the patch?
Old 11-01-2005, 01:08 AM
CslRkH2's Avatar
I'm not sure aboout airing down with the plug though. </div></BLOCKQUOTE>
That's what I was questioning too, the air down effects. Well I wanted to rotate all 5 and not worry about where the plug or patch was when I went off road.
The Toyos did come to mind today
Old 11-01-2005, 01:15 AM
Keep in mind, when airing down, your sidewalls flex quite a bit and if the patch is close, it may be an issue. The way I look at it, when I'm in Moab and on some of those ledges, I TAKE NO CHANCES!
Old 11-01-2005, 01:58 AM
Maybe you should take it back and see if Disc. Tire will pro-rate the tire and get you a new one. Do they know you air down and actually go off road? If they were worried they couldn't fix it, but decided to anyway, I'd be wondering if they wouldn't be willing to help you get a new one. I rotate my spare in, and I would worry all the time. (but I'm a worry wart anyway) I also don't like the idea of anything happening after you drive on it for a few thousand miles, air up after offroading for the hundreth time, and then have a problem at highway speed. I'm with Tim, take no chances.
One more idea. Contact the dealership (parts dept) and ask them if they have any takeoffs. Sometimes they're willing to make a deal if they've got a lot of them in the back. You're still running the All terrains?
Old 11-01-2005, 02:10 AM
On the way to Moab I had to have a tire repaired with a plug in Lexington, KY. It's still fine and it's the least of my worries.
Old 11-01-2005, 02:31 AM
CslRkH2's Avatar
Thanks for all the input. The tires are the ones that came with the truck so no chance of getting any pro-rate, Disc Tire fixed it for free. They were unsure before they pull the tire off the rim, but after looking at it they were confident that it would hold. I figured they would just try to sell me a new tire but they didn't so that makes me think it should be fine on road. Maybe I will contact the dealer and some local tire shops to see if they have a take off.
Old 11-01-2005, 02:33 AM
When I had mine repaired they could NOT get it off the rim. That's why they went with the plug. I like the plug better anyway.
Old 11-01-2005, 02:59 AM
CslRkH2's Avatar
I'm a workin stiff with 2 rugrats....That buck 80 pays a weeks day care
Old 11-01-2005, 03:37 AM
Bondage Bondage is offline
Bondage is off the scale
If you are worried a buck 80 will get you a new one, it's only $. </div></BLOCKQUOTE>
I was gonna say the same thing, but damn! Where are you buying them so cheap? Best price I've found was Tirerack.com at $201.
Sean
Old 11-01-2005, 04:01 AM
Discount Tires. Don't worry I got ripped bad with my MT/Rs, they were 280 a pop I think. </div></BLOCKQUOTE>
WTF?? I just checked on line - and they want $225!!! You have to enter your zip - so the extra forty-five bucks must be for the priviledge of buying them in the People's Republic of Kalifornia.
Sean
ps - when mine start to wear out (and they do get pretty eaten up on the rocks around here) I think I'll go with 37" Nitto Grapplers. They look like they'd be tougher in this terrain, and if nothing else, they look VERY cool.
