Old 06-21-2003, 05:29 PM
Circuitguy
I was washing my H2 this morning when I noticed that it has a slight lean to the drivers side. Now I know I'm over weight but even when I'm out of the truck? HAHA! Ok. The drivers side rear is about a quarter of an inch lower than the passenger side rear. In the front about the same. Is this normal? Is it made to do that? I checked the rear air ride, it goes up and down with the same difference with both. I also checked the tires,all have 40psi. Could some of you check your H2's and see if it's the same or do I have to go back to the dealer again...Thanks! BIG-C
First American Properties Inc. 916-858-2383
White 03-H2-LUX
Circuitguy
White 03-H2-LUX
Old 06-21-2003, 09:17 PM
MAC MAC is offline
MAC is off the scale
I measured my Hummer, from ground to the lower edge of rear trunk door window is 54.5", the horizontal line extends to both side of the Hummer on the rear quarter panels. Exact even height on both sides.
Old 06-21-2003, 10:04 PM
buddy buddy is offline
buddy is off the scale
Sounds like the drivers side torsion bar may need a turn or two. One full turn on the adjustment bolt equals approximately 1/4" ride height, up or down. The dealer can re-adjust the "Z" height and align if necessary or you can use a 3/4"or 18mm socket wrench and make the adjustment. One or two turns probably will bring it where it was originally. Always measure from the frame rails, body panels are not equal side-to-side. It helps to have 1/2 tank of fuel.
Several of the H2s I've checked, have very little room for adjustment and they're all different.Some have more adjustment travel on drivers side, and some have more adjustment available on passenager side. I ask the dealer why, but they don't have an answer.
Then again, the problem may be the rear suspension.
Buddy
Old 06-22-2003, 01:42 AM
DiscoDancingRover DiscoDancingRover is offline
DiscoDancingRover is off the scale
Or maybe the H2 is compinsating for a Discovery's right side lean.
Rover owner, with light envy...
Old 06-22-2003, 11:30 AM
Hummie2's Avatar
Hummie2 Hummie2 is offline
C....
Actually 1/4 inch lower on driverside is pretty close.
Take into consideration the crown in the highway and the effect of engine torque acting on the frame and suspension and I'll bet your H2 is level going down the road. I do know that on my coil suspension there are different rear springs on the right and left rear and the shop manual warns against installing the wrong spring if relpacing one. I would also believe that the same would hold true for air spring, or a different ride height setting to compensate for torque and crown.
Don
Old 06-22-2003, 11:35 AM
DURAMAX TIM is off the scale
Circuit Guy how accurate is the floor u are checking the measurements from?
My garages all have the floor 1" lower in center than the outside so everything goes to the drain.
In concrete work +/- 1/4" is pretty good for flatness.
98 ZR-2 Blazer
Ex H2&3 owner
Old 06-22-2003, 03:36 PM
Circuitguy
Floor is level,half tank of gas inside over weight driver out side and it's still leaning to the drivers side about 1/4 inch. Mabey the torsion bars need cranking,I know that will change the rear height a little. The rear bags are working great up and down. Mabey it should be like that for the crown in the road. I don't know...I'm just a little upset about another problem with the H2. I don't care for the trips to the dealer all the time. C
White 03-H2-LUX
Old 06-23-2003, 11:07 AM
BADRAP BADRAP is offline
BADRAP is off the scale
Did you do what I told you to do? Did that fix it? If not then I am not sure what else to tell you other than dealer time.....Hope it worked...Later
BADRAP
03 H2, Lux, Pewter, Granatelli Diablo Programmer, Airaid intake, TB Spacer, more stuff soon..
H2 Club - Houston Chapter..
badrap@sbcglobal.net
Old 06-23-2003, 01:26 PM
PewterPower PewterPower is offline
PewterPower is off the scale
I have experienced the exact same problem that you describe. I took it to my local dealer and they replaced something...but it still leans....sometimes up to 3/4" ! As you stated, when the vehicle is running and the doors closed, the compresser levels the vehicle so I'm certain that it's level driving down the road...but when it's parked......it seems to lean or "leak down". I'm very interested to follow this thread to see where it goes !
Old 06-23-2003, 08:27 PM
MAC MAC is offline
I did not measure the bumper height because bumpers are attachments, especially the plastic bumper parts, subjected to minor imperfections due to the fittings. My focus is on the level of the body not minor points of the plastuc bumpers. I measured the body of the Hummer at the exact same horizontal points, as stated in my presvious post in this topic. Both points are exactly 54.5" from ground, which proves my Hummer is perfectly leveled.
Old 07-01-2003, 03:34 AM
IT IS YOUR H2 AND YOURS ALONE... MAYBE IT IS THE DEMONS AND VOICES IN YOUR HEAD TELLING YOU THAT IT IS LEANING WHEN IN REALITY IT IS YOU THAT IS LEANING....HAHAHAHAHAHA
BADRAP
03 H2, Lux, Pewter
Old 07-01-2003, 04:25 AM
DROPER DROPER is offline
DROPER is off the scale
No, it is not just his BADRAP. I have/had the same issue. When you are parked flat and walk up to the H2, mine also appeared to be leaning or sagging on one side.
To fix the problem, I have moved the rear sensor levers to compensate for the problem. Worked perfectly. In fact, I didn't really care for the rake the H2 came with from the factory and moved them both to level out the back as well.
The air bags are going to be interesting to watch long term to see how they hold up. I have been screwing around with mine to get it level for a few months off and on.
I don't let my dealer solve these types of problems because they have no solution but to keep replacing everything.
Old 07-01-2003, 04:37 AM
I know man, that was specifically for CircuitGuy and he knows it.... What do the voices tell you now?
BADRAP
03 H2, Lux, Pewter
Old 07-12-2003, 04:17 AM
Circuitguy
Ok. I spent a day at the dealer so to check on the problem I have been having. They said that there is a new software download that they had to install to fix the problem with the rear air ride being unlevel. So I trust that it is was fixed "I just wanted to get home asap!" I took the truck after five hours waiting and drove home. The next day I notice the same lean on the drivers side. ITS STILL LEANING! At this point I do not wish to spend another day at the dealer for a problem they do not know how to fix. I am going to take Badrap's advice and adjust the torshon bars up front to level out the truck. I will let everyone know the outcome to this problem soon. Thanks to all that replied to this thread as every bit of info helps. BIG-C
White 03-H2-LUX
Old 07-12-2003, 04:19 AM
Circuitguy
Where have you been dude! Drop a line or somthun! DUDE! C
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by BADRAP:
_BADRAP_
03 H2, Lux, Pewter
badrap@sbcglobal.net)
<HR></BLOCKQUOTE>
White 03-H2-LUX
Old 07-13-2003, 05:33 AM
Circuitguy
I guess we will find out tomarrow if the adjustment to the front end will fix the problem. I will let everyone know asap. BIG-C
White 03-H2-LUX
