Old 12-27-2005, 04:21 AM
Operator24 Operator24 is offline
Operator24 is off the scale
Whatdiddickforbrainssay? </div></BLOCKQUOTE>
Well that was constructive.
~Veritatem Cognoscere~
Old 12-27-2005, 04:33 AM
4churchill is off the scale
I'm pretty sure Tall Jeeper is ghey
www.HUMMERNut.net
Old 12-27-2005, 04:44 AM
Talljeeper Talljeeper is offline
Talljeeper is off the scale
Nah, I dont work for Rancho.....in fact coming from a competitive racing fourwheelin' world Rancho is so so due to their conservative approach to suspension lifts.
To make a blanket statement that they suck based upon one individuals experience is ludicrous.
I ran down to 10# last weekend over some of the best trails Washington state has to offer and this was all day! Nary a rub....I am also running 35" rubber on 17" Moto's
The knuckle BOLT not the knuckle clears by over half an inch! If a guy was really tripped out over that clearance on the bolt (more than adequate by the way) you could easily replace it with a low profile quality high grade fastener...no biggy
With regards to the "knuckle" there is almost an inch clearance without the bolt....
If you notice the RC pics the tires extend past the fenders even with stock rims.....ok so....does that mean their setup sucks...hardly. Its a flippin wheel configuration.
Reason 3...truck doesn't "feel" stable....sounds like a personal subjective opinion to me....not a design flaw ( I guess if your cruisin north 25 out of Denver at 75-80 I could see why due to the construction, heII nothing would seem stable)
I could give a s*it less what people choose to buy for their rigs, but posting BS, is just that.
It is obvious that many posters don't have a lot of knowledge when comes to fourwheelers, fourwheelin, or moddin trucks. Hopefully those that do will respond with accurate experienced based feedback.
Old 12-27-2005, 04:47 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Operator24:
Well that was constructive. </div></BLOCKQUOTE>
Thx </div></BLOCKQUOTE>
I took the liberty of nominating you here because of you're outstanding display earlier...
http://www.thestupidawards.com/
I bet you win the '06 award hands down.
Old 12-27-2005, 03:17 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Talljeeper:
You obviously chose the wrong wheel design...did you do a trial fit, or did you choose, "Thats looks cool"....seems to me if you had performed a trial fit you would have noted what offest was required. There also the issue of backspace which you never noted as well. <span class="ev_code_RED">4 WHeel Parts checked with Rancho and that backspace/ offset is what was required. 15, 16, and 17" all got the same. 18 and 20" was 5" of backspace. It wasn't enough and required wheel spacers ro it wouldn't touch the nuckle. Rancho's resonse to my questions/ issue was "the wheels should be 20" because that's what the kit was designed with and the kit was not designed to air down your tires." That quote is straight from their tech./ install dept. I'm sure since you drive a mighty Jeep off road, you know how great a 20" rim will do offroad and aired down.</span>
Ranchos H3 system is a very well designed, quality suspension system.<span class="ev_code_RED">It is well built, but the design of where that front nuckle ends up, is total BS... unless your cool with 20" rims or the entire tread sticking out of your fenders.I know you Jeepssters like that look. The problem with that is that some of the states that I go to, will pull you over in two seconds for that.</span>
What you describe as far as ill handling can easily be attributed to tire tread design, improper inflation, poor alignment.....on and on.... <span class="ev_code_RED">Nope, I was assured everythign was aligned and balanced and inflated properly. And it was. The tires are not very aggressive, so I cannot see that being an issue at just higher speeds.</span>
Having had multiple Rancho systems over the years, I have yet to see a poor design from them, including the H3.<span class="ev_code_RED">Good for you.</span>
The H3 suspension is not a rocket science setup....
Also the comment on brakes.....anytime you add rotational mass at the axle brake performance degrades..... <span class="ev_code_RED">Yep, that was his point! Having to use a 20" rim or larger is a bad design.</span>
While the RC setup looks pretty nice, the Rancho won't void the drivetrain warranty like the RC probably will.
You guys need to recognize the difference between these two mfg's..
Rancho bar none produces some of the finest off-road suspension systems manufactured...H3 included.
There is a reason the RC isn't being mass produced an that is to address bump steer issues...I am sure thay will reach a compromise on the design. </div></BLOCKQUOTE>
Old 12-27-2005, 03:28 PM
To make a blanket statement that they suck based upon one individuals experience is ludicrous.<span class="ev_code_RED">that was my opinion on this lift! I don't see where anyone else even said that</span>
I ran down to 10# last weekend over some of the best trails Washington state has to offer and this was all day! Nary a rub....I am also running 35" rubber on 17" Moto's<span class="ev_code_RED">good for you and Jeep.</span>
The knuckle BOLT not the knuckle clears by over half an inch! If a guy was really tripped out over that clearance on the bolt (more than adequate by the way) you could easily replace it with a low profile quality high grade fastener...no biggy<span class="ev_code_RED">The nuckle was more the issue than the bolt was. When you air down to 18 (not that low of a preassure either) You can get the knuckle to stuff into the sidewall at certain angles. I didn't spend 5K on a lift/ rims, and tires so I can drive ti on the street,</span>
With regards to the "knuckle" there is almost an inch clearance without the bolt.... <span class="ev_code_RED">not true ont he setup I had.</span>
If you notice the RC pics the tires extend past the fenders even with stock rims.....ok so....does that mean their setup sucks...hardly. Its a flippin wheel configuration.<span class="ev_code_RED">And that's fine. Nothing some custom flares for $1000 couldn't fix. I think that would lokk like sh1t too!</span>
Reason 3...truck doesn't "feel" stable....sounds like a personal subjective opinion to me....not a design flaw ( I guess if your cruisin north 25 out of Denver at 75-80 I could see why due to the construction, heII nothing would seem stable)<span class="ev_code_RED">You are correct about the I25 North comment, but it was on 470, 25 South, I70 and didn't matter the road surface. But you are correct none the less. I 25 construction sucks in everything.</span>
I could give a s*it less what people choose to buy for their rigs, but posting BS, is just that.<span class="ev_code_RED">Yep, Rancho should advertise that a20' rim is needed. I agree with you.</span>
It is obvious that many posters don't have a lot of knowledge when comes to fourwheelers, fourwheelin, or moddin trucks. Hopefully those that do will respond with accurate experienced based feedback. </div></BLOCKQUOTE><span class="ev_code_RED">I'm sure that statement won't raise any hell! Well, Mr Pro Jeeper, I have responded to every one of your dumbass comments excpet for tha last one about the "posters" not knowing anything about fourwheelersm four wheelin, or modded trucks. that's just a troll statement. You should go back to your pro racing world of Jeeps. LMAO!</span>
Old 12-27-2005, 06:47 PM
Humm3r Humm3r is offline
Humm3r is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">quote:
Thx
I bet you win the '06 award hands down. </div></BLOCKQUOTE>
You're the winner of the "Too much time on my hands Award"
Old 12-27-2005, 10:43 PM
Do you really think I nominated him son?
Please tell me you're not that gullable. Kids these days...
I bet you think the rancho kit is best thing since sliced bread because the guy at 4 wheel parts says it is!
Old 12-27-2005, 10:57 PM
Anonymous Anonymous is offline
Anonymous is off the scale
How many "competetive racing Jeeps" have you seen lately? While I'll admit they are excellent four wheelers and can be built into awesome rock crawlers, nonecould be considered "racing" vehicles. Case in point, of the 359 entries in this years Baja 1000, there were only 3 Jeep entries and none of them finished the race (there was even a Camaro that entered and finished). All of Team Hummer finished and won their classes.
\'06 H3 Slate Blue Adventure
Class winner 1996 Parker 400, Laughlin Desert Challenge, Baja 500...I\'ve never been to the mall!
Old 12-27-2005, 11:10 PM
yea lets hear it for the camaro
Old 12-27-2005, 11:34 PM
FormerJeeper FormerJeeper is offline
FormerJeeper is off the scale
Didn't I warn you all back in the beginning that Rancho made nothing but crap?
Maybe you'll believe me now
-C
Old 12-27-2005, 11:39 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by FormerJeeper:
-C </div></BLOCKQUOTE>
Hey, talljeeper thinks they're the best!
I like their shocks still. I have had good luck with those, but after this, i'm done with their lifts.
Old 12-27-2005, 11:40 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Anonymous:
How many "competetive racing Jeeps" have you seen lately? While I'll admit they are excellent four wheelers and can be built into awesome rock crawlers, nonecould be considered "racing" vehicles. ... </div></BLOCKQUOTE>
Ever heard of Jeepspeed? Its an entire class of cherokees that race all over the country.
Ever heard of UROC? ARCA? Jeeps and tube buggies all competing in rockcrawling events...and it is a race. You're timed. Therefore those are race trucks.
EDITED: (I think I missunderstood you originally Anonymous, sorry) I don't know what you mean by "race" vehicles but you're not comparing apples to apples here. Jeeps and baja trucks were designed to do two different things. Neither can do the other well. I don't see many baja trucks crawling in Lucern and yea, you don't see jeeps wining the baja 1000.
But this topic is less about jeeps vs. hummers than it is about rancho sucking ass at anything more than street wheeling. Lets focus here people.
Old 12-27-2005, 11:57 PM
Whatdiddumbf.ucksaynow?
Who gives a flying f.uck about your "coverage" for the largest off road publication in the world when all you did was suck a lot of dick.
Are you going to report me to some unheard of website for stupid people again
LMAO. </div></BLOCKQUOTE>
Its pretty easy to talk a lot of crap on the web... but to torque me, its going to take a lot more than anything you can come up with sport.
You can stop trying to act cool in front of your friends now.
Old 12-28-2005, 12:11 AM
You can stop trying to act cool in front of your friends now. </div></BLOCKQUOTE>
You’re already admitting e-enragement just by posting back, if you didn’t care you wouldn’t respond kiddo.
The ownage was easy with you </div></BLOCKQUOTE>
You've posted many times on this topic but you've yet to say a single thing concerning the rancho lift (aka the topic at hand). I think you come on here because you can't get laid or someone didn't hug you enough as a child. Maybe mommy denied you the tit when you were 2 months old? Maybe you recently found out you were an accident child? We can rename your birthday "The Big Oooops" if we must. But it doesn't change the fact that you still haven't contributed to a single thing on this topic.
What does that tell you?
Go a head, say it... everyone else already knows, just blurt it out when you figure it out.
