11-11-2005, 01:45 AM
Is this possible or do you need a 2nd compressor?
11-11-2005, 02:12 AM
I would just get an elocker for the front. Having had an ARB I see no problem with a good compressor shop mounting the air line solinoid on the existing air tank. Still see no need to mix systems though.
11-11-2005, 02:17 AM
I'd use/add the stock ARB compressor.
You would need a way to "trip" the air compressor on the stock air suspension to add pressure to the locker solenoid, and then keep it. The stock ARB compressor contains a small air tank to keep and maintain that pressure.
M101A2 Trailer
11-11-2005, 02:33 AM
Thx for the responses guys.
Is there anywhere in the back portion of an SUT to mount an aftermarket compressor?
11-11-2005, 02:38 AM
Is this possible or do you need a 2nd compressor? </div></BLOCKQUOTE>
Not unless you get an allignment done first. </div></BLOCKQUOTE>
