Old 11-16-2005, 08:25 PM
Vt Hummer Vt Hummer is offline
Vt Hummer is off the scale
Help
How do I get my light bar to turn on and off with the Perimeter Lighting on the hummer activates?
Help
Old 11-17-2005, 10:37 AM
Has anybody done this? It's driving me crazy
Old 11-17-2005, 11:55 AM
VTSTOMPER is off the scale
VT:
What are the perimeter lights? Do you mean your DRL/reverse lamps when you unlock the truck in the dark?
I imagine you would need to put in a second "hot" line that would be spliced into that circuit’s positive line. I do not know if I would do that - only because the watts on that light bar are probably more than the wires were designed for.
Is it a factory bar?
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 11-17-2005, 12:02 PM
I poured over the wiring diagrams and the wiring is buried within the BCM circuits. From what I remember I think I found it, but would have to go look again. I was going to wire in some puddle lamps.
An alternative would be to trigger it off of the courtesy lamps inside. Just run a relay triggered by the power to courtesy lamp in the driver's side door.
Old 11-17-2005, 02:07 PM
The Courtesy Lamps should work, But when ever the door is opened won't the lightbars come on too? I was tring to find the wire that send the signal to the DRL's to activate the Perimeter lighting. It seems like it goes thur a timed relay or something. I would like to just lock or unlock the doors and have my lighting come on, like it does with the DRL's and the back up lights.
Old 11-17-2005, 02:14 PM
If I remember correctly, there is one wire each coming from the BCM going to the reverse lights and the DRLs respectively. There is no "external" wire to tap into in either of these circuits for just the perimeter. There is no perimeter circuit that I remember finding exactly.
I have to reload some stuff on my computer and then I will re-visit this idea.
Old 11-17-2005, 03:36 PM
H2Finally's Avatar
There is a long-about way of controling the trigger, by using a set of relays to control the logic.
I.e., backup light on --> brake light on --> interior light on --> then trigger lightbar..
Of course, if you happen to be backing up with your interior light, and you hit the break, your lightbar will turn on but you get the idea..
Can BLING Get You Home?
Old 11-17-2005, 06:49 PM
Thanks for the help. I got a relay. The four pins I have a ground, the device, and the reverse light. I only need one more 12 volt wire that is active when the perimeter lighting come on( besides the DRL's)
Old 11-17-2005, 10:51 PM
I just figured it out. If anybody wants their light bar to come on with the preimeter lights and let me know and i will post the relay diagram.
Old 11-18-2005, 01:14 PM
Don't be like that, tell us what you did.
This might be a good way to add some puddle lamps tucked up in the frame so I don't step in a cow pie at night.
Old 11-18-2005, 06:07 PM
Here is the relay set up to make light bars work with DRL's. Remerber when going from relay number two in pin 86 is a good idea to use a diode. wiring it this way will make sure that the light bar only comes on at night when you push the buttons on the key fob.
Old 11-18-2005, 06:21 PM
Pretty damn cool!
Old 11-18-2005, 07:19 PM
Sorry, This does not function like DRL's. It only functions like the Perimeter lighting option
Old 11-18-2005, 08:14 PM
WOW! Nice work!
Old 11-18-2005, 08:21 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Vt Hummer:
Sorry, This does not function like DRL's. It only functions like the Perimeter lighting option </div></BLOCKQUOTE>That's the point, right?
The circuit is only hot if the DRL's are ON and the ACC is OFF. Correct?
Old 11-18-2005, 08:53 PM
Right. I tried to hook to the DRL's only but when the DRL went on the light bar went on, such as day time. But hooking it up this way only turns it on when the ACC is off and when the DRL's come on. Will only come on when the Perimeter lights come on as described in the owners manual. This works as a switch, you can still hook up to a normall switch too. Just hook into you existing light bar relay on pin 86.
IT works perfect
Old 11-18-2005, 08:59 PM
pics!
Old 11-18-2005, 09:44 PM
Pic's of what? the relay set up or the light bars? I got the front and rear XTC bars.
Old 11-18-2005, 09:52 PM
sure - both. Where did you mount them? (relays)
I would like to see them mounted too (Light bars)
