Old 01-13-2006, 12:30 AM
trail humper trail humper is offline
trail humper is off the scale
I know there has been several posts on this topic and some confusion. I upgraded to the 6 disc stereo to replace may base radio. Installation took about five minutes. My dealer reprogramed the radio and it works fine, no problem with sound levels being cut in half.They charged me 19 dollars to do it. Lynch Hummer, Chesterfield, Mo.
Black H3 Adventure
Black H3 Adventure
Old 01-13-2006, 12:55 AM
Mike E's Avatar
Mike E Mike E is offline
Mike E is off the scale
Good Deal. I did the same thing last week and my dealer charged me $50.
____________________________
Old 01-13-2006, 12:58 AM
H3Eric H3Eric is offline
H3Eric is off the scale
I will do it as well. Earlier posts indicated that the volume level would be cut in half. I have the moonsoon system, I'm not sure if there is a 6 disc without moonsoon
Old 01-13-2006, 01:11 AM
from the two threads i think low volume was 6 disc no amp if you have monsoon you already have the amp so you will be thumpinnnn !!!!
Old 01-13-2006, 01:32 AM
I meant I bought the 6 disc stereo that was part of the moonsoon system via Ebay. In my H3 I have the base stereo. Anyway I will just try it.
Thanks,
Eric
Old 01-13-2006, 03:21 AM
if volume is issue after install just get an affordable amp
Old 01-13-2006, 12:44 PM
Mike E's Avatar
H3Eric, you should be fine. I added the 6 disc premium radio from the standard radio and the volume is fine.
Old 01-13-2006, 04:39 PM
H3Eric, I was concerned too, but my H3 just had the base radio without the monsoon speakers, and the 6 disc works great, no volume loss, I think it is even louder with cd's over the am/fm.
Black H3 Adventure
Old 01-13-2006, 08:45 PM
Thanks, I will change it next week.
Old 01-19-2006, 03:15 AM
I finally installed my 6 disc radio instead of the stock radio. It sounds great and it does not lock, so I don't have to go to the dealer.
This is very strange as all other posts here about the change talked about the unlocking of the radio by using a tech-2 at the dealership.
Old 01-19-2006, 04:57 AM
Greg\'s H3 Greg\'s H3 is offline
Greg\'s H3 is off the scale
I did the same thing have monsoon with single cd, bought 6 disc radio on e-bay.My first question how did you remove the cover plate so you could remove the radio,any special tools required?
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by H3Eric:
This is very strange as all other posts here about the change talked about the unlocking of the radio by using a tech-2 at the dealership. </div></BLOCKQUOTE>
Old 01-19-2006, 12:03 PM
Mike E's Avatar
Stick your fingers in the two accessory ports at the bottom lower right and pull up and out. The panel will pop off.
Old 01-19-2006, 04:57 PM
First Hummer is off the scale
disconnect the battery first before you do anything.
Old 01-19-2006, 05:13 PM
Mike E's Avatar
Na, just cram your fingers in the sockets. It'll be fine.
--yes, disconnect the battery.
Old 01-19-2006, 05:16 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Mike E:
--yes, disconnect the battery. </div></BLOCKQUOTE>
And move the shifter into 1st/2nd before you disconnect the battery. It will make things a lot easier.
Old 01-19-2006, 06:14 PM
MrsRobinsn2000 MrsRobinsn2000 is offline
MrsRobinsn2000 is off the scale
Hi Trail humper...........I don't have a reply to your post I just wanted to say Hi.
Old 01-20-2006, 01:09 AM
the same here, maybe will catch you in the chat room soon.<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by MrsRobinsn2000:
Hi Trail humper...........I don't have a reply to your post I just wanted to say Hi. </div></BLOCKQUOTE>
Black H3 Adventure
Old 01-20-2006, 05:34 PM
If there is a set day and time that you know you will be in the chatroom just let me know. You can either post it here or email me. Talk to you soon.
Old 01-23-2006, 05:04 AM
501 501 is offline
501 is off the scale
Can anyone tell me if the 6-disc changer can play MP3 CD's also?
