Old 10-15-2005, 12:45 AM
psywzrd psywzrd is offline
psywzrd is off the scale
Is there any way to raise the seats on an H3 with the Lux package? (yes, I know they can be raised using the button on the left side of the seat). I want to know if there's a way to raise them maybe a couple inches or so to give yourself a more commanding view of the road.
Old 10-15-2005, 01:03 AM
Vandakeg Vandakeg is offline
Vandakeg is off the scale
telephone book?
Old 10-15-2005, 01:09 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Vandakeg:
telephone book? </div></BLOCKQUOTE>
lol yeah, put it on the seat - it will give you a good 2-3 inches....
Old 10-15-2005, 11:27 AM
Webb70 Webb70 is offline
Webb70 is off the scale
Or bigger tires to raise the seat (and the rest of the truck)
Old 10-15-2005, 11:54 AM
- you know, I tried 3 telephone books, put it on the seat I had a great view my head is sticking out the roof (moonroof)...
Old 10-15-2005, 11:58 AM
Desert Dan's Avatar
On my Wrangler I raised the front seats an inch because on the newer Wranglers you sit lower than previous models.
I used small metal blocks cut to the size I wanted as spacers between the floor board and seat mounts. Use longer bolts as needed (grade 8 bolts for safety)
I have seen other people use metal tubing and hocky pucks or roller blade wheels as spacers.
I am sure something like this could be done on an H3?? Make sure you have slack in any of the electrical wires etc.
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 10-16-2005, 03:38 AM
x-humm x-humm is offline
x-humm is off the scale
I raised mine in my '73 Thing (little Hummer)after I performed a 3" body lift. I built an adaptors that attached the floor pan to the seat rail. There is not adaptors for Hummers, you would have to built one yourself. Give yourself enough headroom, specially if you go Off-roading alot...good luck
Old 10-16-2005, 04:18 AM
kacyk's Avatar
kacyk kacyk is offline
kacyk is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by psywzrd:
Is there any way to raise the seats on an H3 with the Lux package? (yes, I know they can be raised using the button on the left side of the seat). I want to know if there's a way to raise them maybe a couple inches or so to give yourself a more commanding view of the road. </div></BLOCKQUOTE>
I wonder if your seat is working corectly. After reading your post I put mine all the way up and my head is at the ceiling. I usually have it all the way down.
2003 Yellow H2 LUX (Sold)
Old 10-16-2005, 01:16 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by kacyk:
I wonder if your seat is working corectly. After reading your post I put mine all the way up and my head is at the ceiling. I usually have it all the way down. </div></BLOCKQUOTE>
I was actually wondering that myself. I'm definitely able to raise the seat but it doesn't seem like it raises very far (kind of like the dashboard lights not dimming very much...
Old 10-16-2005, 01:38 PM
H3wannabe H3wannabe is offline
H3wannabe is off the scale
Something definetly sounds wierd. I am only 5'8" and I can put my seat up too high.
H3wannabe
Slate Blue, Lux, Auto, Cashmere Interior and Tow Package.
Old 10-16-2005, 02:37 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by H3wannabe:
H3wannabe </div></BLOCKQUOTE>
Really? I'm about 5'9" and I can't raise the seat up too high. I would say I have at least 4-5 inches of headroom to spare when the seat is all the way up. Does this sound right to you? You're about the same height as me so our results should be similar.
Old 10-16-2005, 09:52 PM
H3OwnerDiz's Avatar
H3OwnerDiz is off the scale
Really? I'm about 5'9" and I can't raise the seat up too high. I would say I have at least 4-5 inches of headroom to spare when the seat is all the way up. Does this sound right to you? You're about the same height as me so our results should be similar. </div></BLOCKQUOTE> You're better off if you each raise your seats all the way up, then use a tape measure and measure to the ceiling, then comparing results. Torso and leg lengths vary. Does the passenger side have power seat controls that you can compare against? (I don't have power seats so I don't know if it's on both seats or not)
T & A Beeeotch!
Boulder Grey H3
Old 10-16-2005, 09:57 PM
jkH1+H2=H3 jkH1+H2=H3 is offline
jkH1+H2=H3 is off the scale
I keep my seat as low as it can go, at 5'7".5, It's cool to get that humvee feeling where people can't see you, very stealthy!!!!
Old 10-18-2005, 11:09 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content"> You're better off if you each raise your seats all the way up, then use a tape measure and measure to the ceiling, then comparing results. Torso and leg lengths vary. </div></BLOCKQUOTE>
That's a good idea. I'll measure mine with the seats all the way up and I'll post my results.
Old 10-18-2005, 01:43 PM
fourfourto's Avatar
I beleve cieling is lower in sunroof installed h3's
Old 10-18-2005, 05:14 PM
Klint's Avatar
Klint Klint is offline
A babys hichair you can get them used for around $5 on Ebay
Klint T.
2007 Black Lux, Blinged out
