Old 03-03-2005, 03:26 PM
DH22G's Avatar
DH22G DH22G is offline
DH22G is an unknown quantity at this point
? Iam changing diff covers and I need to get new gear oil of course. I was going to go with Royal Purple Gear Max but i didnt know what weight to go with. The lady at the shop said that 75-90? was the more common. I dont know gears and oil if my life depended on it.. Any sugestions? I need a good synthetic oil and the purple i heard to be the best.
- DH22G
David
2007 Acura TL Type S
DH22G's Avatar
- DH22G
David
Old 03-03-2005, 03:36 PM
Kevin B Kevin B is offline
Kevin B is off the scale
Here's some good info and Phil knows of what he speaks
Old 03-03-2005, 03:48 PM
DH22G's Avatar
awesome thanks guys.. so when i bolt it back up i bolt the whole thing and then where is the filler hole? i know iam a retard first timer here!
- DH22G
David
Old 03-03-2005, 04:02 PM
It looks like the fill hole on Phils is on the side.
Hey thats funny..........Phils fill hole .........OH MY
Old 03-03-2005, 04:06 PM
DH22G's Avatar
my cover does not have any drain or fill holes.. is there a spot on top of the dif case? also how fill should these be? completely?
- DH22G
David
Old 03-03-2005, 04:10 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">my cover does not have any drain or fill holes.. </div></BLOCKQUOTE>
I guess you will have to put the oil in and slap the cover on real quick .
Seriously though, that sucks .
Old 03-03-2005, 04:34 PM
The manual says the rear diff only holds 4 pints, but that just doesn't seem right. I put in 7.5 pints with a new diff cover. </div></BLOCKQUOTE>Ok, a little wierdosity here. Phil, I just looked at the service CD and the '03 ballpark capacity is listed at 4 pints, but the '04 and '05 says 2.75 quarts. Maybe there was a change to the chunk or to the cover between '03 and '04 and your cover is more like the '04/'05 one.
DH, you really need a cover that is designed for the the H2. The fill plug is also the check plug, so without it there is no way to see how much oil is in your differential.
Old 03-03-2005, 04:36 PM
RIC-H0's Avatar
RIC-H0 RIC-H0 is offline
I would send it back if it doesn't have a fill hole.
"cause what they sent you was a really expensive helmet!
Ric-H2
www.meatspin.com
Old 03-03-2005, 04:37 PM
Phil, there was a drain plug on the bottom of the housing wasn't there? I think i remember it being there and not on the cover.
Old 03-03-2005, 05:06 PM
Phil does trialduty.com have the best price on the black with polished fins? I'm going to change mine out but do not want polished look underneath. I'm calling dealer today as I want them to tell Me what I'm seeing from people that know what they are doing. this to me is very disturbing. I'm headed out right now but late today or Friday i'm pulling the check plug and see what is in there. I do not run mine as hard as you guys or close to it but, it is designed to do what You do and that is all the fluids will take! I'm going to get all synthethic and change everything to Mobile 1. I was going to go with Redline but the ordering and waiting I have decided I do not want to get into that. Same with Royal Purple. I have visited with a few mechanics and they say Mobile 1 is as good as any for the application I'm using it for. Could You give an update on the dino oil and the synthetic that some of You have put back in? ALSO, have any done a temp check as discussed in Phil's thread?
TAZ
Old 03-03-2005, 05:42 PM
Uh, I must be wrong in my thinking as far as capacity goes. I was under the impression that if the fill hole is on the side you fill the diff to that point. That way you can't overfill it. The overfill just flows back out. So if that is true and the filler is on the side, just go buy 6 pints and return the left over.
Of course, this could be totally wrong and that would make this a useless post.
Old 03-03-2005, 05:54 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by sfox:
Isn't the drain hole shown in ths pic? </div></BLOCKQUOTE>I thought there was one on the housing. Now Phil has TWO cloaca.
Are you sure there is no fill hole on the other side? This is a different GM diff, but they seem to be consistant on some things:
http://www.off-road.com/chevy/projects/kickin/pml/
And here is a pic a different one, still:
