04-22-2005, 09:44 PM
No, shoot him in the crotch. Then maybe he would speak english for a few.(it's probably located above the beltline of his jeans)
04-22-2005, 11:10 PM
Nah I think its probably located between his belt line and sneaker.
04-28-2005, 12:16 AM
UPDATE: Well I still have not put any silicone anywhere as of yet. But today, I opened up the sunroof and sprayed water directly into it. Nothing. Also, the water leak is not from underneath, because it leaks while sitting in my driveway. However, I did finally get it to leak when I sprayed water "near" the corner roof light. I know the rubber gromet makes a nice tight seal under that light, so I think that the leak is occurring under the exterior a-pillar body molding (that part that covers the driver's side edge of the windshield). I see that this piece is held in place with screws (maybe the leak is around these screws?), so does anyone know how to remove this molding? Also, I took the interior a-pillar trim off and it was nice and dry on the inside. I'm determined to get this fixed!!! :-)
White 2003 H2 LUX, all options (except NAV system), DVD system, backup camera, lightbar, etc.
04-28-2005, 11:50 AM
One more quick question (in addition to the question in my previous post asking for help removing the exterior trim panel on the driver side edge of the windshield). Let's say that I am wrong about the water leaking from behind that exterior trim panel and that the water is really leaking from one or more of the three center roof lights. Wouldn't the water also travel down the a-pillar on the passenger side and soak the carpet over there? The dry carpet on the passenger side is one of the reasons why I have been thinking that it can't be the center roof lights. I really wish I had structural pictures of the H2 body before everything is put on it (windshield, dash, trim, etc.). I know I'm asking a lot, but your help is really, really appreciated!!!
05-05-2005, 07:38 PM
I had the same problem, took it in and they said the problem was the front roof ligts. They repaced them and all of the carpeting front and rear.
05-05-2005, 09:27 PM
After taking my car into the West Covina,CA dealer 5 times, the leaking into the carpet and insulation finally stopped. But I recently washed my car pretty thoroughly, and there was a small puddle of water not directly under the carpet, but right under the plastic trim.
I've submitted a complaint or whatever it's called with the Better Business Bureau and GM said they want to settle, but haven't called me back, so I'm waiting for the Better Business Bureau to go into an arbitration hearing.
I'm tired of this leaking problem, but I'll live.
05-05-2005, 11:22 PM
Unlike most of you guys with brand new H2s, I bought mine one year used but with 33,000 miles on it, so the original GM warranty was over after I drove it 3,000 more miles. I had enough foresight to get a 6 year extended warranty, but that does not cover leaks...something I really didn't expect to have happen. Murphy's Law I guess. :-( And there's the other old saying: "buyer be ware".
Anyway, I have been able to successfully "control" the leak by routing the water around the front door hinges and wiring harness boot. (I used a concoction of weather stripping that I picked up at the local hardware store.) For a more permanent fix though, I just need to figure out a way to get my hands in there to spread some silicone around the hinges and the rubber boot. Anyone have any suggestions??? Is it easy to take the door off the vehicle so that I have more room to work?
05-10-2005, 07:53 PM
I've decided to open up a lemon law suit with a lawyer, and since it will probably take a while, I'm going to continue to make some mods on my car.
-Sound System
-Lower (springs, shocks, torsion keys)
-Full tints
-Suede Headliner
-Already have 22" rims
