  #61
Old 04-21-2006, 08:50 PM
H3HUMVEE's Avatar
H3HUMVEE H3HUMVEE is offline
H3HUMVEE is off the scale
Originally posted by RubHer Yellow Ducky:
H3HUMVEE
HAVE you double and triple checked your math skills like we asked.
BECAUSE
Your the only one in the country or anywhere getting that kind of mileage...
RYD
RYD... I can assure you I can easily calculate my gas mileage and I'm sorry all your gas mileage sucks ... how many people on here that have posted there mileage are driving the 5 speed manual transmission ?? that's what mine is.
_. __________
H /__________\
3[O][][][][][][O]
Old 04-21-2006, 08:59 PM
fourfourto's Avatar
For those of you who are running the Adventure package or are running 33's, please adjust by increasing your total mileage by 3.7%.
Wouldnt the adventure package be properly calibrated from factory?
H3HUMVEE
BECAUSE
For high mpg you could fill up on top of a hill that is 10 miles long coast down it at 65mph at the bottom refuel you mpg will be sky high
I did it with a murano and the gas computer said 99.9 mpg by the bottom of the hill
In that situation the H3 should get at least 75mpg
Old 04-21-2006, 09:20 PM
Only once in over 15K miles have I hit 18mpg. But I haven't tried any long downhill runs with a fillup and I haven't fixed my lead foot.
S.
Old 04-21-2006, 09:33 PM
So, if you're ran 100 miles on the odometer, you've actually run 103.7 miles.
The 3.7 percent can make a difference in regards to your overall MPG. For example (in a perfect mathematical world using 11 gallons of fuel exactly):
Running 32's (base/lux)
200 Miles run
11 Gallons used
200/11 = 18.18 MPG
Running 33's (Adventure)
200 Miles run (on odometer)
207.4 miles actual (3.7% difference)
11 Gallons used
207.4/11 = 18.854 MPG
Why? There are different calibrations for the off-road and the regular package. I have to assume GM has a different odo calibration in each one. So, if the vehicle came from the factory with the larger tires, the odo SHOULD be correct, those who installed larger tires will have an innacurate speedo. Even with that, your calculations will not be accurate for all H3s.
My speedometer is off by under two miles at 70 mph, calculated on two separate GPS units, on two different trips, and I even did the mile marker versus the stop watch a few times on flat ground in IN.
I'm probably getting a little less in mileage than I stated earlier, but it would be about .4 per mile.
Since those trips, I have uploaded two different calibrations but have not rechecked the miles on the speedo versus the GPS units. Hopefully, one of those calibrations corrected this error.
(NOTE: Federal Law allows a 5$ plus or minus on speedos.
Old 04-21-2006, 09:57 PM
Called a few other people today, 9, and the best of the 9 is 18.3, so 50 owners and no one over 20
Old 04-21-2006, 10:13 PM
Goosey Goosey is offline
Goosey is off the scale
So far I am so impressed with this vehicle that I almost forgot about mileage. I bought the base model with not one single option. (Don't need anything else) Slate blue. 5 speed. I decided when I bought it to either take the trrain to work, or keep it under 65 (barely).
Anyone driving nice and keeping track of mileage with a standard?
Old 04-21-2006, 10:20 PM
H3HUMVEE's Avatar
I call Bull Sh*t... sure you know 9 other H3 owners you could call all in the same day and find out there gas milage ...
_. __________
H /__________\
3[O][][][][][][O]
Old 04-21-2006, 10:25 PM
H3HUMVEE's Avatar
Welcome to the forum ... keep it under 65 and shift when the indicator flashes on the dash and you should get 20+ MPG .. of course no one on here will believe you
_. __________
H /__________\
3[O][][][][][][O]
Old 04-21-2006, 10:27 PM
Originally posted by H3HUMVEE:
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Agriv8r:
I call Bull Sh*t... sure you know 9 other H3 owners you could call all in the same day and find out there gas milage ... </div></BLOCKQUOTE>
Call if you must, but I am a dealer and already keep contact with about 103 (according to my list) H2 owners and close to 137 H3 owners (again according to my list). I talk to about 35 or so a week, throughout the week, about issues there are having, MPG, future Happening events. A couple are members of this forum. I had records of 41 with MPG reports this morning and wanted to round the firgures off to an even 50. Not all of them keep accurate records, so i only commented on the ones that assure me they do. I use this for sales (realistic expectations) and also to keep an inside track on issues in our area. But if you must call I believe the numer is 1-800-BUL-SH*T. Have a nice day
Old 04-21-2006, 10:34 PM
H3HUMVEE's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by H3HUMVEE:
Call if you must, <span class="ev_code_RED">but I am a dealer</span> and already keep contact with about 103 (according to my list) H2 owners and close to 137 H3 owners (again according to my list). I talk to about 35 or so a week, throughout the week, about issues there are having, MPG, future Happening events. A couple are members of this forum. I had records of 41 with MPG reports this morning and wanted to round the firgures off to an even 50. Not all of them keep accurate records, so i only commented on the ones that assure me they do. I use this for sales (realistic expectations) and also to keep an inside track on issues in our area. But if you must call I believe the numer is 1-800-BUL-SH*T. Have a nice day </div></BLOCKQUOTE>
Oh... your a car sales man In that case I belive anything you say
_. __________
H /__________\
3[O][][][][][][O]
Old 04-21-2006, 10:45 PM
Oh... your a car sales man In that case I belive anything you say </div></BLOCKQUOTE>
NO SIR! I am associated with HUMMER sales, not cars, not SUV's, after all, LIKE NOTHING ELSE!!
Old 04-21-2006, 11:14 PM
Scouts Out's Avatar
i have been doing allot of high way driving (Pittsburgh to Harrisburg) and Pittsburgh to Ft Knox and pittsburgh to Ft Dix. I consistantly averge over 18 and closer to 20 when I set the cruise at 75mgp and relax. Around town ( lots of hills) just sucks at around 12 mpg.
Other Cars.....
1980 Triumph TR8 3.5 litre V8
Old 04-21-2006, 11:47 PM
Av1ator Av1ator is offline
Av1ator is off the scale
Let me throw one more log on this fire.
Maybe the ones that are getting really poor gas milage are ones that have low compression problems and don't know it yet.
My milage certainly got better after they put the new top end on it. Last tank I got 17.8 mostly interstate at 70 MPH..I do have the automatic transmision with adventure package. I have really tried to get better milage by watching the speed and the best I have seen is 18.2. Maybe with careful driving the smaller tires and the 5 speed you can break 20 MPG but I wouldn't have the patience to do it everday.
Old 04-22-2006, 12:29 AM
LOOK
Cut all the name calling and BS.
All i'm saying is that only ONE person that we know of is getting 20+ MPG on the AVERAGE. I don't know how many are registered on the H-3 Forum, lets say 500 (i know i'm way off to high AND to low) but thats 1 in 500. The odds can't be correct, OR theres a lot of people who have compression problems and if thats it then GM has a really BIG PROBLEM.
SO
without name calling and BULL CHIT has anyone got a GOOD LEGIT ANSWER???
RYD
Old 04-22-2006, 01:03 AM
You bite your tong!!
I would have to say that my average of 13 MPG is a matter of 90% city driving, almost always running 75-80 when on the highway and a not so light foot. I wish I was getting 17 or better but I love driving the H3 so much that I am still extremely happy driving it at 13 MPG.
Old 04-22-2006, 02:19 AM
Well, before all my mods I was getting 17.8 mpg average mostly city driving. But now I'm getting 12.4 mpg...but it's all good, gas mileage is never an issue for me, even I get 5 mpg I'll still be driving my H3 and go off roading.
Old 04-22-2006, 08:55 AM
DarthKarl's Avatar
DarthKarl is off the scale
Yeah, I think that has something to do with it. I know I've put on a lot of weight (to my rig, not myself ). With the weight of my UCP, roof rack, hi-lift, air compressor, toolbox, etc...its all got to have an effect on the mpg
Old 04-22-2006, 10:08 AM
Interesting thought, but the PCM will start registering misfires, and turn on the MIL light, as soon as there is any notable wear in the intake valve guides of cylinder one. In addition, a rough idle should start quit soon after the MIL light comes on.
If you drive with the misfires, it might affect mileage enough to be noticeable; not sure.
Old 04-23-2006, 04:24 AM
I do know my fillup tomorrow will cost well over $50. Chevron regular is running over $3.00 in Silicon Valley.
S.
Old 04-23-2006, 07:37 AM
I still only see one (1) person averaging 20+ MPG (city/hwy). Maybe he has an experimental engine in his that we or he doesn't know about
{huh, f5}
OR
As was stated the entire fleet of H-3's has compression problems (EXCEPT HIS)
OR
His math skills are lacking...
RYD
