Old 01-05-2003, 09:20 PM
SOFTTAILJC's Avatar
SOFTTAILJC SOFTTAILJC is offline
SOFTTAILJC is off the scale
where did i see the replacment allen head screws for the dash? someone sells 10 screws in a set that look way better than factory zinc ones... hate it when i can't find the site or forgot to save........soft
SOFTTAILJC's Avatar
Old 01-06-2003, 12:09 AM
redrum redrum is offline
redrum is off the scale
You can get them from Predator motorsposrts. I have a set but didn't put them on because the stock ones look better to me.
Old 01-06-2003, 12:14 AM
SOFTTAILJC's Avatar
thanks redrum, i think your right....soft
Old 01-11-2003, 12:53 PM
JCJ JCJ is offline
JCJ is off the scale
Redrum,
Would you care to exchange those allan head screws w/ a bottle of Arubean rum?
Old 01-11-2003, 02:05 PM
Kühl Carbon Kühl Carbon is offline
Kühl Carbon is off the scale
Folks, please be carful replacing these screws. There was an issue with early vehicles and the IP retainer .... the big plastic piece of structure that holds all of the IP components. The towers that the allen head screws screw into on the centerstack were a little weak and the plant had some problems with breakage .... mostly due to torque on the guns being set to high. Just be gentle on removal and under no circumstances should any type of power tool be used to re-install them. Run them down by hand and you should be fine.
Founding member of the "No Hummer Krew"
Founding member of the \"No Hummer Krew\"
