Old 10-30-2003, 12:58 AM
AlaskaH2 AlaskaH2 is offline
AlaskaH2 is off the scale
Has anyone had their turn signals just quit working. The turn lights are coming on, but will not blink. I looked at the two fuses and they appear fine. Any thoughts or suggestions, or should I put this on the to be fixed list for my dealer. Thanks.
Old 10-30-2003, 03:55 AM
Circuitguy
Sounds like you may have a signal bulb that is burned out, a bad flasher or a problem with the trailer wireing.
GM cars and trucks will keep the signal lights on solid without flashing when a bulb is burned out or there is a problem with the flasher or trailer wireing. BIG-C
White 03-H2-LUX
</a>
Old 10-30-2003, 04:44 AM
Thanks. I'm taking it in to the dealer tomorrow. Have several issues that need to be fixed. The catalytic converter/muffler pinging, my windshield washers (front and back) don't work. Now the turn signals are out. So it is time to take it in.
Old 11-01-2003, 06:38 PM
Circuitguy
You have many og the same problems my H2 had. My dealer was great and repaired all the problems and now it works ok. They changed the Wiper Moter, Muffler two times, Drive Shaft, Transfer Case Tail Housing and Seal, Tail Gate Trim, Steering Shaft Lower Bearing, right side Grab Handle, It sounds like a lot but for a first year production H2 its probley normal. I would expect to 04 to have these things worked out on it. BIG-C
White 03-H2-LUX
</a>
