Old 04-29-2003, 05:31 PM
Hummer Man is off the scale
Is it true or only in certain states.
Old 06-24-2003, 12:30 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by kdio:
I was at a Hummer event hosted by Hummer of Sacramento and SMA was there with their H2. They had the PIA 520 installed at the DRL location. They said they are going to offer this as a kit for sale. Should be available in May.<HR></BLOCKQUOTE>
I've received an email today from SMA that says it's called the H2 Valance and they will now be available sometime in July.
Old 06-24-2003, 11:35 AM
Hum2's Avatar
Hum2 Hum2 is offline
Hum2 is off the scale
The other thing I would recommend is using the Pilot mini-round switches, would make it much easier to install in the place shown. A suggested easier switch location is in the grey panel to the lower right of the left air vent.
Ric
OMAHOG/IHOG
Hum2@cox.net
OMAHOG/IHOG/MHC
Hum2@cox.net
www.OMAHOG.com
Old 06-25-2003, 10:30 AM
Hum2's Avatar
Once I get my 03 Navigator foglight fixtures installed into the H2, I will write it up.
Stopped at a U-Pull-It auto salvage yard yesterday to yank a few bulbs out of existing vehicles. This place has a $2.00 admittance fee, and the guy saw my handfull of wires and bulbs and said see ya!...That was $0.50 each, not too bad.
Got the wiring and bulbs for 4, 9006 HB4 halogens. The bulb wiring socket is similar to the 03 Navigator 9145 H10 bulb socket except for 2 guide notches vs. 1, which can be removed so both bulbs will fit in the same socket. That was going to be my only hang-up with putting in the 9145 fixtures (the dealer parts places don't have the wiring for these fixtures unless you by the entire vehicle harness).
Going back to get the 9005 base from some vehicles as this base is for a slightly less wattage bulb and might not need the tab modification. (The 9145 socket is based off the 9005/9006 platform, I just picked up 9006 sockets, not thinking there would be much difference).
Enough for now...more when I get the fixtures in to see how much work it will be to install into the H2, but it looks pretty straight forward.
Ric
OMAHOG/IHOG
Hum2@cox.net
OMAHOG/IHOG/MHC
Hum2@cox.net
www.OMAHOG.com
