  #461
Old 01-27-2006, 08:02 PM
rodster rodster is offline
rodster is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Bondage:
<span class="ev_code_RED">I went to Penn State a long time ago. Better?</span> </div></BLOCKQUOTE>
Oh, so you're older than dirt? I relate.
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content"><span class="ev_code_RED">K. You made me look that up. Were non-xanthochroid students required to wear pale merkins?</span> </div></BLOCKQUOTE>
Nice circle!
\'05 SUT
Old 01-27-2006, 08:07 PM
Bondage Bondage is offline
Bondage is off the scale
Nice circle! </div></BLOCKQUOTE>
Sean
Old 01-27-2006, 08:09 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by ree:
And you don't have to actually bring your rig do you? I think it exceeds airline size restrictions. </div></BLOCKQUOTE>
The SUV does, yes. The SUT fits in the overhead compartment.
Sean
Old 01-27-2006, 08:42 PM
Racer-X's Avatar
Racer-X Racer-X is offline
Racer-X is off the scale
CB came yesterday! I bailed on my original antenna idea and stopped and bought a 2' firestick while I was in Sacramento this a.m. Looking forward to installing all of it this weekend.
Tie rods ordered. Hopefully they get here in time to be installed and have alignment done. Then I can bring the old for spares incase we lose one....or two.
Sean, I hear ya about looking forward to this with alot of crap going on in life. I'm in the same boat, I really really need this trip. Thanks again for the invite. Only two weeks!
Old 01-27-2006, 08:52 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Racer-X:
Sean, I hear ya about looking forward to this with alot of crap going on in life. I'm in the same boat, I really really need this trip. Thanks again for the invite. Only two weeks! </div></BLOCKQUOTE>
T minus 355:26:50 and counting...........
Sean
Old 01-27-2006, 09:00 PM
RODSTER;
Do you have a pic of your rig fitted out with your "modified" magnetic skins? And dontchya hate the little thin strips that go under the front and rear doors???? I've almost lost those several times.
Sean
Old 01-27-2006, 09:12 PM
CB came yesterday! I bailed on my original antenna idea and stopped and bought a 2' firestick while I was in Sacramento this a.m. Looking forward to installing all of it this weekend. </div></BLOCKQUOTE>
I just did that project a few weeks ago. Lots of good antenna tips in this thread. If you need any help along the way, lemme know.
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Tie rods ordered. Hopefully they get here in time to be installed and have alignment done. Then I can bring the old for spares incase we lose one....or two. </div></BLOCKQUOTE>
Anybody here done the tie rod repair?
\'05 SUT
Old 01-27-2006, 09:19 PM
Do you have a pic of your rig fitted out with your "modified" magnetic skins? And dontchya hate the little thin strips that go under the front and rear doors???? I've almost lost those several times. </div></BLOCKQUOTE>
How embarrassing. I still had chrome and little tires ...
\'05 SUT
Old 01-27-2006, 09:21 PM
I've been thinking about painting the shields to match. Watcha think? Any suggestions on primer, prep or paint?
\'05 SUT
Old 01-27-2006, 09:22 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content"> Anybody here done the tie rod repair? </div></BLOCKQUOTE>
Repair? or Replacement?
Old 01-27-2006, 09:23 PM
Different angle, better shot.
\'05 SUT
Old 01-27-2006, 09:24 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by HummBebe:
Repair? or Replacement? </div></BLOCKQUOTE>
Good point. Replacement (in the field) would make sense, yes?
\'05 SUT
Old 01-27-2006, 09:51 PM
Racer-X's Avatar
Good point. Replacement (in the field) would make sense, yes? </div></BLOCKQUOTE>
Nope. From what my buddy tells me it's very simple...a "cake walk" were his exact words. He even said a tie rod fork was unnecessary and that he'd show me "a little trick to replacing them". I plan to do it myself with him instructing me. I'll be ready for it if it happens.
BTW - Rod, did you say you had a air filler unit? Any idea what the PSI output is? If it's within range I'll bring air wrenches to make any repairs even easier. I'll also bring a torque wrench. geeez, I need to make a list.
Old 01-27-2006, 10:05 PM
BTW - Rod, did you say you had a air filler unit? Any idea what the PSI output is? If it's within range I'll bring air wrenches to make any repairs even easier. I'll also bring a torque wrench. geeez, I need to make a list. </div></BLOCKQUOTE>
Here's what the manufacturer says (although they also offer performance specs of typical CFM at 90 p.s.i. for various tools.)
Because of high outlet pressure tool damage is possible and extended tool use is not recommended. Most air tools are not rated to accept 150 p.s.i. DO NOT USE with tools that are NOT rated for a maximum pressure of 150 p.s.i.
\'05 SUT
Old 01-27-2006, 10:08 PM
How embarrassing. I still had chrome and little tires ... </div></BLOCKQUOTE>
The tires are allright. The chrome sucked out loud. Outstanding job on extending the shields! As far as painting them to match, um, well, um, why not paint that gawdawful pewter thing to match the shields?
Sean
Old 01-27-2006, 10:10 PM
Racer-X's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Because of high outlet pressure tool damage is possible and extended tool use is not recommended. Most air tools are not rated to accept 150 p.s.i. DO NOT USE with tools that are NOT rated for a maximum pressure of 150 p.s.i. </div></BLOCKQUOTE>
****!!! now I gotta throw the compressor on the rack! Anybody bringin a generator? LMAO!
Old 01-27-2006, 10:15 PM
BTW - I've never changed the tie rods on the H2, but I did break a tie rod on my old JEEP!!! LOL Changed that in the field, no problem. I'm sure we could manage - and I have some printed instructions from BLUEHUMMER where I bought the "Tie-Rod Repair Tool Kit."
IMPORTANT NOTICE:
There will be no broken rigs on this trip. Thank you. That is all.
Sean
Old 01-27-2006, 10:16 PM
Outstanding job on extending the shields! </div></BLOCKQUOTE>
Thanks very much. Little patience and (too much) time works wonders sometimes.
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">As far as painting them to match, um, well, um, why not paint that gawdawful pewter thing to match the shields? </div></BLOCKQUOTE>
A. Black is not a color. It is the absence of color.
B. Black is evil. Pewter is light. Therefore black is for leftists, pewter for right.
Disclaimer: Does not include Vegas H3s.
\'05 SUT
Old 01-27-2006, 10:17 PM
****!!! now I gotta throw the compressor on the rack! Anybody bringin a generator? LMAO! </div></BLOCKQUOTE>
Actually, I think JonStitz said he actually WAS bringing a generator! LMAO
Anybody bringing a mobile home and workshop/garage?
Sean
Is that a bit much?
Edit: Is 150 psi a bit much?
\'05 SUT
