Old 02-05-2006, 06:03 PM
Newdl Newdl is offline
Newdl is off the scale
Please help. I just got my hummer. As you can see in the picture I got it from NFL player Dante Hall of the KS City CHEIFS. It currently has 24" wheels on it and I purchased stock takeoff's from my dealer for $795 yesterday (still has tits on tires).
I want to change the 24's to the 17's tomorrow, but my floor jack only lifts 6-21 inches. This does not seem like high enough to put on the stock tires (make the car about 4" higher than the 24" wheels do.)
PLEASE LET ME KNOW YOUR SUGGESTIONS!!!!
Old 02-05-2006, 06:09 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Newdl:
</div></BLOCKQUOTE>
You sure you don't want to rethink this question? I suggest you take it to a professional if this has you stumped.
Old 02-05-2006, 06:11 PM
WOW if the rest of the members on this forum are as helpful as you I am sure glad I took the time to sign up.......Thanks for nothing "guru"
Old 02-05-2006, 06:14 PM
SOFTTAILJC's Avatar
SOFTTAILJC SOFTTAILJC is offline
SOFTTAILJC is off the scale
USE YOUR JACK AND A PIECE OF 6X6 TO TAKE OFF RIMS..........SOFT.....
Old 02-05-2006, 06:16 PM
Thanks softtailjc.............just what is soft?
If I were to buy a new jack....what would i need it to lift to? Or does everyone here either
A: use the jack that comes with the truck
OR
B: Use some sort of spacer between the jack and the floor as softtailjc mentioned
Old 02-05-2006, 06:56 PM
WOW if the rest of the members on this forum are as helpful as you I am sure glad I took the time to sign up.......Thanks for nothing "guru" </div></BLOCKQUOTE>you're welcome
Old 02-05-2006, 07:06 PM
H2Finally's Avatar
Ugh, Newdl, what Para said has some merit. If some things are beyond your knowledge (especially if that thing involves 8,000lbs of steel, plastic and rubber ) -- seek pro help. Won't cost you more than $100.
Why do you need to lift the truck more than 21" to swap the wheels?
Can BLING Get You Home?
Old 02-05-2006, 07:18 PM
shipbldr shipbldr is offline
shipbldr is off the scale
You can use the stock jack...
If you are going to buy a jack, get this one:
http://www.trailduty.com/products/hilift/index.html
Get the 60" version. It'll work anywhere and stores easily under the back seat.
I have one on my roof. Many of the folks here that off-road have hi-lift jacks.
Be damn careful jacking up your truck. They are very heavy.
I had an incident with a jack last fall that sent me to the emergency room to have my lip sewn back togther...
Have fun, welcome to the board...
Old 02-05-2006, 07:21 PM
CslRkH2's Avatar
CslRkH2 CslRkH2 is offline
</div></BLOCKQUOTE>
Do you have a pick of the jack under the back seat??
Old 02-05-2006, 07:27 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by CslRkH2:
</div></BLOCKQUOTE>
Do you have a pick of the jack under the back seat?? </div></BLOCKQUOTE>
I put amps and in inverter under the back seat so it won't work in my truck anymore (so I can't do a picture you....) right now my Hi-lift jack is up on the Gobi rack...
Old 02-05-2006, 07:32 PM
Arizona Hummerboy's Avatar
I would go with a 60" Hi-Lift Jack, to jack up your truck. If you have jack stands, you could also use them for extra security.
Old 02-05-2006, 08:30 PM
Boss Hoss's Avatar
Boss Hoss is off the scale
That truck appears to be lowered...if this is the case the stockers may not fit.
Old 02-05-2006, 08:41 PM
Dug Dug is offline
Dug is off the scale
newdl-- Like paragon, i am also being serious . If you cant figure out how to make your jack lift the vehicle , you should be very careful because you are not qualified to change the tires. I am not being a ******* , but i am probably saving you from damaging yourself or the truck. Good luck
Old 02-05-2006, 10:25 PM
id imagine the owners manual would provide more insight on this, ummm, just follow the directions, dude
Old 02-05-2006, 10:45 PM
I have 8 cars. 3 of them classic (1954, 1961 and 1980) I can do work on cars myself. I have yet to get my HUMMER back from the undercoater to even try a jack on the vehicle (I also have only had the truck at my home for 24hrs before it went to the shop). It was a simple question as to if anyone uses a similar jack. I appreciate your genuine concern, but if I had the vehicle I wouldn't ask the question. I want to get the vehicle back, change the wheels and get it to the dealer for warranty work all in about 1.5 hrs time. This was an attempt to be prepared.
How much play the STOCK suspension has Directly relates to if this car can be jacked up using my jack. Something I would not know if I didn't have the car HERE. (VOL)
Thanks to those of you who treat new comers with respect and curtesy one would expect from a fellow human being. FOR THOSE OF YOU WHO ACT BETTER THAN EVERYONE ELSE: Take time to learn from other forums who actually care.
I only hope that driving a HUMMER doesn't make me treat others as some of you do.
(1st and last discussion ever posted my NEWDL)
Old 02-05-2006, 10:57 PM
(1st and last discussion ever posted my NEWDL) </div></BLOCKQUOTE>Yippee!!!!! Like anyone here cares.
Dude, send in your Cialis rebate card and get a new set of balls.
Suspension play has nothing to do with jacking it if you had half a brain. You did say you had a floor jack. One would naturally assume if you had it you would know how to stick the sumbitch under each corner and flop the tire/wheels.
Old 02-05-2006, 11:15 PM
MovinH2's Avatar
MovinH2 MovinH2 is offline
MovinH2 is off the scale
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Thanks to those of you who treat new comers with respect and curtesy one would expect from a fellow human being. FOR THOSE OF YOU WHO ACT BETTER THAN EVERYONE ELSE: Take time to learn from other forums who actually care. </div></BLOCKQUOTE>
HA HA HA. Your barking up the wrong tree here man. . Their about to eat you alive run.
Old 02-05-2006, 11:25 PM
Is this a troll post?
I'll do the humanitarian thing:
Through this holy anointing may the Lord in his love and mercy help you with the grace of the Holy Spirit.
May the Lord who frees you from sin save you and raise you up.
Through this holy anointing, may the Lord pardon you whatever sins you have committed.
(Last rites, Latin Catholic Version)
Old 02-05-2006, 11:43 PM
I hate to say this but I agree with most of these guys. If you're asking such a simple question (regardless whether you have the vehicle in front of you) then I'm not sure you're capable of doing the job correctly. If you have 8 cars, surely you're mechanically inclined to figure out what is needed.
Since you don't have the truck in front of you, I don't see what kind of answer you honestly expected. You know yourself that you're going to have to wait until you can see how the jack fits underneath the truck.. but of course, you already knew that.
No flame but it was a ridiculously simple question.
Good luck.
Mark
