06-14-2005, 03:11 PM
Hello Everyone
I just a bought a 2003 Hummer H2 and have a few questions. My Fog lights are not working, fuse and lights bulbs are ok, but in the fuse box the relay that should be in FOG are not there?? I took the working HORN relay and tested but nothing happend??
One other question: The perimeter lighting is not getting off when I programm it off in the car??
rgds
Tomas
Hello Everyone
rgds
Tomas
06-14-2005, 03:19 PM
If you are referring to the stock DRL(Daytime Running Light), those are not suppose to come on when the headlight is on. I believe you can re-wire it to turn on with the headlights, do a search under DRL.
Please be more specific on your second question
06-14-2005, 03:35 PM
Ok, thanks for the reply. But is there any switch somewhere for the fog lights??
The perimeter lights: From my steering wheel I can go inte the menu that says perimeter lights on/off, if I put it in off the lights are still on??
rgds
Tomas
FINLAND
06-14-2005, 03:48 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Viper:
rgds
Tomas
FINLAND </div></BLOCKQUOTE>Tomas, post a pick of the front of your truck. If you're talking about the two lights below the headlights, then they are Daytime Running Lights and NOT fog lights. There is no switch as they come on automatically when the truck is put into gear during the day.
Perimeter lights, are you talking about when the truck is turned on or off with the key fob? You cannot just drive around at night with the lights off.
06-14-2005, 04:04 PM
Hello Ken
Thanks for the reply. Yes im talking about the two lights below the headlights. Ok so this is not Fog lights, but anyway this lights are off all the time, what can be wrong??
The perimeter lights, Sorry I thought that was the orange lights at the front of the roof.
rgds
Tomas
06-14-2005, 04:27 PM
The orange lights on the roof cannot be turned off. the perimeter lighting turns on with the key fob so you can see where you're going at night (drl's and reverse lights). The DRL's should be on during the day and off with headlights on. Are your headlights always on? Is the truck still under warranty?
'03 H2
06-14-2005, 04:34 PM
Hello dochummer
ok, Now I knows everything about the orange ones. My Headlights are not always on.
06-14-2005, 06:05 PM
The perimeter lights: From my steering wheel I can go inte the menu that says perimeter lights on/off, if I put it in off the lights are still on?? </div></BLOCKQUOTE>Same with my '03, you can't turn them off. don't know if they fixed it on later years, but on '03's that setting does not seem to work. </div></BLOCKQUOTE>Guys, I really think that's referring to lights when unlocking/locking the truck. You have several options there.
Of course I'm not going to the garage and pulling the cover, climbing in and messing with it just for you.  Which means I'm probably wrong, but check it out. You may be surprised.
06-14-2005, 08:32 PM
Amazing what you can learn from reading the owners manual  </div></BLOCKQUOTE>
...but is that REALLY necessary???  Who has the time when there is a forum like this!  (Time for a little reading!)
___________________
05 Desert Sand H2 Adv
06-14-2005, 09:05 PM
For inside lighting, there is a button on the dash that keeps interior lighting from coming on when you open the doors.
