Old 01-26-2006, 05:41 PM
Here's a couple pics I took when installing the UC protection, sorry no action shots. It may not be as beefy as the RB stuff for the H2, but its all that's out there right now AFAIK. It does feel pretty sturdy. And it definitely beats the stock protection over the TC.
Old 01-26-2006, 05:42 PM
Old 01-26-2006, 06:29 PM
H3Eric H3Eric is offline
H3Eric is off the scale
In an earlier post there was a message that there was a new underbody protection kit available from GM. (this thread had to do with the modications to the rough country lift kit).
Does andybody have more news about this?
Old 01-26-2006, 08:46 PM
ETD's Avatar
ETD ETD is offline
ETD is an unknown quantity at this point
Sewie, thanks for the pics. Were they easy to put on? Any pitfalls in the installation that I need to avoid? Thank you.
Old 01-26-2006, 10:46 PM
The install was pretty easy. The only problem I had was that my dealer had replaced one of the skidplate bolts with a shorter one. So I was playing musical bolts to get everything to fit.
Old 01-26-2006, 10:48 PM
A couple other items of note.
1. You lose about 1" of clearance. Would be nice to have ones that tucked up between the crossmembers.
2. They collect mud like a mofo!
Old 01-26-2006, 11:04 PM
partsguy partsguy is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Sewie:
2. They collect mud like a mofo! </div></BLOCKQUOTE> They sure do!
walc's Avatar
walc walc is offline
walc is off the scale
You lose about 1" of clearance.... </div></BLOCKQUOTE>
Now, I have to think, again.
Is it worth losing 1" of clearance, when I only have 32" tires?
KenP's idea may be a better alternative; specifically:
"BTW, this is what I'm thinking about trying:
Taking some 1/4" plate and weld it to the stock UCP. Then cut some large holes for ventilation. Cheap and it should last a while."
2008 Ford F250 Super Duty, 6.4L PSD, XLT, 4x4, LB.
2006 Hummer H2 SUT.
2003 Land Rover Discovery S.
2007 Mercedes Benz E350.
2006 BMW M3 Convertible.
2007 Harley Davidson FXD Dyna Super Glide.
Old 01-27-2006, 02:38 AM
RIC-H0's Avatar
RIC-H0 RIC-H0 is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by walc:
Taking some 1/4" plate and weld it to the stock UCP. Then cut some large holes for ventilation. Cheap and it should last a while." </div></BLOCKQUOTE>
Don't forget, if the skid plate is keeping the big rocks away from your undercarriage, it's also keeping lots of mud away from the pressure washer and out of site. You'd be surprised how much mud can accumilate ontop on things under there! It will pack up under there and eventually cause lots of heat build up! If you do make the skid plates, make them easily removable, maybe a rivets, and not welded.
IMO
Ric-H0
www.meatspin.com
Old 01-27-2006, 02:42 AM
RIC-H0's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by HIHUMMER:
You need to hurry up and get your A$$ to VA so you can rub my new rocks and slide on them!!! </div></BLOCKQUOTE>
Fissed!!! Mo Betta!
www.meatspin.com
Old 01-27-2006, 03:37 AM
hmrlvr's Avatar
hmrlvr hmrlvr is offline
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">If you can't be a good example...Then you might as well be a horrible warning! </div></BLOCKQUOTE>
Love that, did you think of that yourself? I have family in San Antonio, my wifes. It's nice there.
WWW.BCBI.COM
Old 01-27-2006, 04:12 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by RIC-H2:
Fissed!!! Mo Betta! </div></BLOCKQUOTE>Rick, if you're moving to the Great Commonwealth, you better PM us now.
As to the accumulating mud:<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content"> KenP
Posted 01-22-06 08:43 PM
http://elcova.com/groupee/forums/a/tpc/f/2606011751/m/5...621019351#7621019351
Take an oscillating sprinkler and put it under your truck near the front and let it run for awhile, then move it to the middle, then rear. It does wonders. </div></BLOCKQUOTE>Best I can do.
If you're really worried about it, take your UCP to a local welder and tell them what you want. It WILL be cheaper.
Old 01-27-2006, 09:23 AM
DarthKarl's Avatar
DarthKarl is off the scale
x2 Yes they do!
Old 01-27-2006, 12:26 PM
RIC-H0's Avatar
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by hmrlvr:
Love that, did you think of that yourself? I have family in San Antonio, my wifes. It's nice there. </div></BLOCKQUOTE>
It's my lifes' philosophy!
Thanks...I love San Antonio. Big town with a small town feel, and there is always a party going on! The Rodeo is coming up, then comes Fiesta, then spring festivals, then summer festivals, then...!!!
Too bad I may be leaving S.A. for work!
Ric-H0
www.meatspin.com
Old 01-27-2006, 12:31 PM
RIC-H0's Avatar
[/quote]Rick, if you're moving to the Great Commonwealth, you better PM us now.
[/quote]
I may be moving up there within the month of Feb. I'll keep y'all updated. I guess I'll just have to show you how it's done here in Texas! Bigger is always better!
www.meatspin.com
Old 02-26-2006, 12:56 AM
CampMaster CampMaster is offline
CampMaster is off the scale
After you've had a few weeks to test them out... what do you think of them?
Is it worth the 1" loss in clearance??
Old 02-26-2006, 03:38 AM
FormerJeeper FormerJeeper is offline
FormerJeeper is off the scale
Seems a hell of a lot of money for what is essentially 1" or so box section steel.
IMHO, it would be better to use this type of ladder framework and then add 1/4" plate over the top of it.
I know when we used to armor Jeeps for trails like Rubicon the thought of leaving stuff open like in these picures is less than ideal.
-C
