11-21-2002, 06:04 PM
Has anyone else found the outside temp reading to be 4-5 degrees off? I know it should only be used as a referrence, but could be useful in winter to watch out for ice on the road.
11-21-2002, 07:16 PM
Sounds like we we have a couple of bad sensors or mirrors. Going to check out the local GM dealer to see if they will warrenty it.
11-21-2002, 08:30 PM
My temp read-out on the mirror seems to be 3-4 degrees off. If your 30-40 degrees off you may have it set to read Celsius, hehehe!
Jim
Red H2 in Texas
Jim
2008 H3 Graphite Lux
11-21-2002, 09:20 PM
It was a good thought,(had me stumbling out the door in a heartbeat), but it's Degrees F. I've watched it jump form 35" to 90" in less than a Minute. I understand the sensor is mounted in the bumper and is failing.
11-21-2002, 11:07 PM
My mirror uses the numeral 9 where it should use the numeral 4 when the temperature is in the 40's.
38 -> 39 -> 90 -> 91 -> 92 in the morning.
51 -> 50 -> 99 -> 98 -> 97 in the evening.
See my post in the general discussion forum. I guess we need a software upgrade?
12-02-2002, 07:32 PM
Mine does the same thing, but only when I'm stopped or idled for a while. However, once I'm underway again, the temperature goes to the right setting. Don't you think the huge shift in temperature reading might be a result of heat from the engine?
12-23-2002, 06:06 PM
Same problem with mine too. Took it to the dealer and they will replace the mirror. Can't figure out the problem.
12-31-2002, 08:02 PM
Me too! It's kind of funny to have snow on the ground with the temperature reading 98.
Reminds me of the islands ......
01-01-2003, 12:21 AM
After the mirror was replaced the problem went away. The Tech said they have been replacing several, Bad Mirrors.
01-02-2003, 10:11 PM
This is why I like this forum. The outside temp display showed 27, then 47 and back to 31 in a blizard. I am going to get the mirror changed as soon as it is time for service.
01-04-2003, 08:24 PM
Maybe the problem could also be (in temp. increase) that the sensor is in the bumper and the engine heat could make it warmer.
 New York Rules
01-04-2003, 11:38 PM
To rapid of a change for A J or K type thermal couple--or any thermal couple for that matter--Would venture to guess they use a grounded junction type to give a stable/steady output to prevent erratic readings.
01-05-2003, 10:06 PM
Get it through your heads: this is /not/ a sensor problem. It's simply lighting an extra freaking fluorescent bar. When it tries to write a 4 it makes a 9, and when it tries to write a C it makes an E. OK? Get it? It's not a sensor problem, it's not a calibration problem. Thank you... Next please.
01-06-2003, 12:24 AM
You are correct--it isn't a sensor problem, it a bunch of bad mirrors. And it's more than A LED problem...Bad Mirrors, Bad Mirrors, Straight from the dealer, pay attention here H2XOR--Bad batch of mirrors.........I have had NO problems since it was changed out.
[This message was edited by Big Z on January 05, 2003 at 06:37 PM.]
01-06-2003, 03:10 AM
Play nice!!
"I smell varmint poontang."
01-06-2003, 03:34 AM
I was playing nice, Just forgot the Smiley face! And my 60 Minutes were up.
