04-18-2006, 05:13 PM
Alright I noticed a post on this site that you have to get a diffrent bumper but no one ever responded. The reason I am making another topic is because the last Hitch question went into other topics so here we go..
Alright if I want to get this hitch
http://www.hitch-web.com/proDescrip....e=411019&OID=8
do I have to get a diffrent bumpper how hard is this going to be to install?
Curt Mfg. Curt Class III / IV Receiver. (Capacity: 5000 / 5500 )
Click here for Installation Sheet in the PDF format.
You will need Acrobat (r) Reader installed to open the file(s). You can download it for free from www.adobe.com
Remember to Install it after the download is finished. GENERAL INFORMATION
* Class III / IV, Receiver Style, 2 inch Square Hitch. Does NOT include Ballmount, Pin and Clip.
* Comes Complete with All Mounting Hardware and Installation Instructions.
* Weather Tite Construction Prevents Rusting from the Inside Out by Sealing the Main Body.
* Open Back End on Receiver for Easy Cleaning.
* Attractive Seamless One Piece ProDesign Receiver Tube Collar Reduces Rust.
* Wheelabrator Preparation and Durable Black EverGloss Powder Coat Finish Resists Rust and Corrosion.
* Limited Lifetime Warranty to Original Purchaser.
2006 Hummer Hummer H3 4 Wheel Drive Sport Utility 4 Door SPECIFIC INFORMATION FOR SKU # 411019 FOR 2006 HUMMER HUMMER H3 4 WHEEL DRIVE SPORT UTILITY 4 DOOR >
WEIGHT CARRYING RATINGS
GROSS WEIGHT CAPACITY 5000
TONGUE WEIGHT CAPACITY 500
WEIGHT DISTRIBUTING RATINGS
GROSS WEIGHT CAPACITY 5500
TONGUE WEIGHT CAPACITY 550
STATUS:
# Current Production Item.
A LITTLE ABOUT APPEARANCE:
Crossmember of This Hitch is Nestled Behind the Vehicle Bumper or Fascia.
FOOTNOTES:
1. NO Drilling Required !! ...
 Klint T.
2007 Black Lux, Blinged out
04-18-2006, 05:28 PM
The OEM hitch requires the bumper with the cutout since it sits up higher. Aftermarket hitches should sit below the bumper. No cutout needed, but it will affect the departure angle.
04-18-2006, 06:46 PM
would you buy one?
 Klint T.
04-18-2006, 06:49 PM
Originally posted by Klint:
would you buy one?
Depends on if you plan on wheeling it or not. I did see an H3 bumper with hitch on ebay the other day for $400. A decent hitch is going to cost minimum of $200 isn't it?
04-18-2006, 06:57 PM
No I just need one so I can pull my boat I don't take my Hummer off the road.. I am just like that, I do it for the looks
 Klint T.
04-18-2006, 07:01 PM
Interesting email I got from GM the other day  : "After checking into this a little further part number 15850415, has been discontinued, and is no longer available from GM".
Poor me because part "15850415" was H3 rear bumper without hitch! WTF. I am hoping that what f5fstop wrote on another thread about GM changing part number is true in this case. I mean they can't just stop making rear bumpers, right? Help. S.O.S.
04-18-2006, 07:09 PM
would you buy one?
I ordered mine with the hitch, so no.
If you don't wheel, and you don't mind the way it looks, then go for it.
04-19-2006, 01:10 AM
Well the URL that I posted is that a good one? or is it a waste of $200
 Klint T.
04-20-2006, 03:54 AM
Ordered
87406 Hidden Hitch Class III Trailer Hitch Receiver 1 $135.02 $135.02
Shipping: Ground: $15.82
Sales Tax: $0.00
Total: $150.84
 Klint T.
04-20-2006, 03:59 AM
did you need a drop hitch? if so how many inches
 Klint T.
04-21-2006, 03:59 AM
Klint- I have that exact Receiver your looking at. No you dont need the bumper with the cut out. The Receiver fits perfect under the bumper. I too tow a boat. I have a 4" drop hitch and the trailer sits level and that's with 315's.
As far as the install, I had a local Trailer shop do the install. Took them 30 min including the wiring. Hop this helps.
Anything is Possible.
04-21-2006, 08:14 AM
Parts guy might be able to answer this better, my access does not give me updated or revised part numbers.
They could have changed part numbers, or they could have deleted that bumper, only offereing the bumper with the cutout, that MIGHT have a plate installed that can be removed for a hitch addition at the dealers.
Best suggestion is call the dealer and have them check.
04-21-2006, 11:20 AM
Your running 315s? Lets see some pics of how they look.
04-21-2006, 01:03 PM
Originally posted by HummerNewbie:
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by Scott D:
Your running 315s? Lets see some pics of how they look. </div></BLOCKQUOTE>
X2 pics....
