02-16-2004, 12:28 AM
I don't see any decription that says this is a Hummer factory fuel door. I do not think OEM means Hummer. What makes you think it is from Hummer? Regardless, it is nice.
02-16-2004, 12:40 AM
SOCRATES(Hummer Veteran) posted on 2-1-4 "BEst Billet Fuel Door" and picture that match the pics on Ebay. He discribes it as the "Genuine Hummer Fuel Door" and asked if anyone knew when it would be available.
The pictures match but there is no discription. Thats why I made this post.
thank for your reply.
02-16-2004, 01:57 AM
Troy,
Yes, the door you have won is a Genuine Hummer fuel door.
OEM refers to "Original Equipment Maufacturer," so yes, you are bidding on the Genuine item.
This item is currently available on Hummer-Parts.com for $158.00 -- Hummer Fuel Door Link
Post some pictures after you install it!
Best Regards,
-Justyn
Black '04 H2 -- GOBI Ladder, Corsa, and.... ?
05\' Black SUT
02-16-2004, 02:00 AM
The door which is manufactured by AMP RESEARCH is now only sold through GM and is not available through SMA. It is identical to the SMA / AMP RESEARCH DOOR but with the added HUMMER LOGO.
02-16-2004, 02:05 AM
One change to the new door that many do not know is that its now made of metal instead of billet aluminum. It also comes with a locking replacement gas cap. Just a little heads up before everyone runs out and buys one! BIG-C
White 03-H2-LUX
 </a>
02-16-2004, 02:17 AM
Hey Big C,
Do you know if the locking gas cap that comes with that new fuel door will fit an 03? From what I have read the gas caps are different on the 03's and 04's and are not interchangeable. Also whats the deal with the metal fuel door as opposed to billet aluminum? Will the metal one pit and rust faster than the billet?
S&B Member
02-16-2004, 02:27 AM
Thanks for info on the metal door----They did not say that and I am concerned that it may be inferior!
02-16-2004, 04:54 AM
Spike,
The gas caps are different from the 03 to the 04. The locking gas cap that comes with the new gm fuel door only fits the 04. I could be wrong as it is a bit early to make hasty statments but I have yet to see one that would fit an 03. BIG-C
White 03-H2-LUX
 </a>
02-16-2004, 05:01 AM
H2mildandwild,
The fuel door looks the same from the outside and operates like the old one but it is a different feel when opening and closing it. Its easy to tell that billet aluminum was not used. Now did anyone think that GM would use real billet aluminum on a production vehicle? Not!! BIG-C
White 03-H2-LUX
 </a>
02-16-2004, 10:43 AM
Take the fuel door away from SMA and give to GM---what a fool I was to think it might not be crap!!! GM never surpises me anymore. I have not had a GM vehicle since 1975. My new Hummer rolled off the lot and started to rattle after 30 miles were on the OD. I love the damn thing--just bought my second H2 buy not because it is a GM product.
02-16-2004, 07:02 PM
For all interested, I called AMP Research today and spoke at length with a guy there that I met at SEMA, Las Vegas.
The OEM door is cast aluminum, not metal. It is not CNC machined like the SMA door because GM will not pay for CNC'd parts. He claims that from the outside, you will not tell the difference. The open door is not as pretty because you will see casting marks--GM will not pay to clean that up either.
I have the origional SMA chrome fuel door and will order the OEM one from Hummer-partss.com. Then I will put them side by side and see if the guy is right.
02-17-2004, 02:47 AM
Thanks for the info! I did not do the research like you did. When you feel and touch the door it feels like pot metal. Billet aluminum would have been nice but it does look the same from the outside. I think after all the newness wears off we will see some very affordable pricing on this fuel door. A billet door has to cost more to make! BIG-C
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by H2mildandwild:
I have the origional SMA chrome fuel door and will order the OEM one from Hummer-partss.com. Then I will put them side by side and see if the guy is right.<HR></BLOCKQUOTE>
White 03-H2-LUX
 </a>
02-17-2004, 02:53 AM
This fuel door is what comes on the new Victory Red H2's. It is a GM part and dealers should be able to order them from the factory now that the Victory Red's are out.
2004 Yellow Lux H2 w/Sunroof, Navigation, Corsa Sport, 20% tint, chrome door sills & bumper inserts. (Chrome side air vents on their way!)
2003 Hummer H1 open top
2011 Mercedes C63
02-17-2004, 02:55 AM
Up close shot on the Victory Red fuel door from the factory...
2011 Mercedes C63
02-17-2004, 03:34 AM
Got mine from Hummer-parts today ($158.38), very easy to install. HUGE before&after impact. Didn't install the locking cap (becuase it has no tether).
Here in sunny SoCal, pitting is not a concern. IMHO VERY HAPPY WITH IT!
04 Pewter
02-17-2004, 10:03 AM
MMPH2 & H2Finally:
Thanks for the close ups of the GM door!
02-17-2004, 10:28 AM
Might be the pic.. but it doesn't look straight?
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by H2Finally:
04 Pewter<HR></BLOCKQUOTE>
02-17-2004, 06:36 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by noc:
<HR></BLOCKQUOTE>
NOC, my driveway is at an angle, haven't bothered to check (eyeball looks OK). The door is held by 3 plastic tabs (snap-in) instead of screwed in like the original. Therefore, quite easy to 'wiggle' straight, if necc. Thanks for the heads-up!
04 Pewter
