Old 09-19-2005, 08:46 PM
Motostew Motostew is offline
Motostew is off the scale
O.K. I am almost done except the wiring on my predator drop down tire carrier, but I can not for the life of me figure out how to mount the lock/latch to the arm of the carrier. any help would be great I am stuck and losing light.
Old 09-20-2005, 12:55 AM
xonxoff xonxoff is offline
xonxoff is off the scale
it's too late for pix, it's raining. The latch goes in the opening with the key hole to the right. There is a u bracket that bolts on from the inside that holds the latch in place. you then adjust the lock bolt until it holds the latch tight. I just bought a black lock . I will try to install it tomorrow night and get some pix
Black 04 H2
Old 09-20-2005, 01:08 AM
dochummer's Avatar
did you guys have any problems installing the pin that holds the a-arm up? I rcvd a replacement a-arm and the pin does not fit through the top of the a-arm...(the one that is removed to allow the carrier to drop down.)
'03 H2
Old 09-20-2005, 09:59 AM
Thanks, but I did get the latch in, it was a bit of a pain threading the bolt from the inside. Now I have forward and back play at the swivel. Not a vibration but I can move it about .5 to 1 inch by pushing on the tire. Any thoughts. Maybe the bearing aren't seated right?
Old 09-20-2005, 10:01 AM
That pin is a pain. I had to keep threading it in and out to get it just right. Then when I installed the tire I had to redo it again due to the weight of the tire I guess.
