Old 09-11-2005, 12:23 AM
kacyk's Avatar
kacyk kacyk is offline
kacyk is off the scale
We have begun discussions with our local Hummer dealer to sell them our H2 and buy a H3. It's my wife's daily driver so I do agree with her that the H3 will suite that purpose better (for her).
Our H2 currently has 35/12.50-18 Toyo Open country Mud Terrains. The model H3 we are considering has the off road package so it sits an inch higher. I know the wheels can't transfer but does anyone know if the tires will fit without issue?
Please let me know as I am having their used car manager give me a value for my rig.
2003 Yellow H2 LUX (Sold)
kacyk's Avatar
Old 09-11-2005, 12:55 AM
They'll fit with Rancho's new lift for sure.
Old 09-11-2005, 01:16 AM
kacyk's Avatar
I'd love a lift! But...do you think true 35's will fit without a lift?
Old 09-11-2005, 01:26 PM
sredish sredish is offline
sredish is off the scale
The only reason it sits 1" higher is because it's fitted with 33's instead of 32's. There's a thread in the Gallery area of a stock H3 with 35's on it. They did it fine. I also think they tweaked the torsion bars a little, but it wasn't necessary.
03 Ford F250 - Black - 6\" lift - 37\'s
90 YJ Wrangler - Red - 5\" lift - 33\'s
06 H3 - Yellow - lux package (wife\'s)
Old 09-11-2005, 01:42 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by kacyk:
Please let me know as I am having their used car manager give me a value for my rig. </div></BLOCKQUOTE>
What is the true diameter of those tires?
Old 09-11-2005, 02:27 PM
kacyk's Avatar
The "true" measurement of these tires are 34.5 inches.
Old 09-11-2005, 05:08 PM
goose's Avatar
goose goose is offline
goose is off the scale
i was just looking at nitto terra 315/75-R16. it measures 34.49 inches and 12.32 inches wide(as per website info). i think this is the same size tire Humv installed on his rig, only he use mickey thompsons.
2006 Black SUT
Old 09-11-2005, 09:42 PM
felsmann felsmann is offline
felsmann is off the scale
Very few tires actually measure 35", you should always go to the manufacturer's website and look into the overall diameter of the tire. Most 35" tires run between 34.5 & 34.8
Old 09-11-2005, 10:37 PM
humv humv is offline
humv is off the scale
The size rim and offset will also depend if they fit or not. I have 315/75/16 on stock wheels and they fit fine.I see some guys are running with the tire sticking out quite a bit and I guarntee you it will chip the crap out of your paint! I have the Mickey Thompson MTX's. I did crank the torsion bars 1.5" but did not need to do so to make them fit.
Old 09-12-2005, 02:42 PM
H3H H3H is offline
H3H is off the scale
I gave my torsion bars 5 cranks, it looks like it's ~ 2 inches higher. From a glance, 35s would fit easy.
Old 09-12-2005, 06:01 PM
MyxH3 MyxH3 is offline
MyxH3 is off the scale
They will fit.. might want to turn up the front torsions a turn or two but the width is still the same as the 33"s. I have seen two in the Phoenix area aready running 35's and they both said no rubbing and still using the stock wheels.
May the next exit offroad be anywhere you want it to be.
