Old 02-01-2004, 06:25 PM
SOCRATES SOCRATES is offline
SOCRATES is off the scale
Hi All,
I had the CE light appear yesterday, and I'm sure it is due to my Stant locking gas cap. I had a "Tighten Fuel Cap" twice now, but last night the CE came on instead. I have replaced the cap with the original, and plan on getting a locking fuel door this week. In the meantime, can I clear the CE light via disconnecting the battery, or will this not work? If not, will I have to take it to the dealer (a hour ride from here may I add)?
Thanks in advance!
Black '04 H2 w/ Adventure & Luxury Packages. Corsa on the way!
05\' Black SUT
Hi All,
Thanks in advance!
05\' Black SUT
Old 02-01-2004, 07:07 PM
This does not specifically state Hummer, but...
http://www.automotiveforums.com/vbulletin/t158148.html
Flatrater []
Moderator
Status: offline
11-29-2003, 08:12 PM Re: 96 Regal Light (Post #3)
You cannot clear codes on any GM above a 96 model year. You cannot get flash codes in 96 and newer. Only way to clear codes is with a scan tool.
You need to go back to that shop demand your money back since they didn't fix the problem!
Go to the dealer and have them fix it. 1996 was the first year of OBD2 and evap codes. Your car computer monitors fuel vapor leaks.
ASE Master Tech
ASE Advanced L1
GM Master tech
11 years dealer trained
Bumper to bumper tech
Licensed Avaition mechanic
Please post or PM me I will answer within 2 to 3 days. If you email me it may take up to a week to answer. Give as much info as you can. Make, model, year, engine, trouble code and trouble code description. Help me help you. The more you tell me the more I can help you!!
Report Post | IP: Logged
Hope this helps and hope this is wrong.
Try disconnecting the battery for 5 minutes.
Black Lingenfelter Lux
Old 02-01-2004, 07:52 PM
Thanks, Ken.. I'm going to give the battery disconnection a try and see what happens.
-Justyn
05\' Black SUT
Old 02-01-2004, 08:00 PM
HMSH2 HMSH2 is offline
HMSH2 is off the scale
CONDITIONS FOR CLEARING THE MIL/DTC
The control module turns OFF the Malfunction Indicator Lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
Use a scan tool in order to clear the MIL and the DTC.
Hood Motorsports
- 1967 427 L71 Corvette (99%+ Bloomington Gold Certified, restored to original)
- 1998 Lingenfelter 383 C5 (over 500hp and 11\'s in the 1/4 mile)
- 2001 GMC Yukon Denali (22\" wheels and tires, extensive multimedia system, and per
Old 02-01-2004, 08:05 PM
Left the battery disconnected for a couple of minutes..
Check engine light is gone, thank goodness. Thanks for the posts..
-J
05\' Black SUT
