Old 12-01-2005, 12:01 AM
FishnMan's Avatar
FishnMan FishnMan is offline
FishnMan is off the scale
For anyone considering the Nokya Arctic White H13 and H10 replacement lights, check out this link. It would apprear these lights are weak and actually less effective than the stock lights. Whew, and I was just about to buy them! I raelly want a whiter/brighter light without the HID price. Guess I'll wait until Silverstar makes an H13 and/or H10.
Link: http://www.f150online.com/forums/ search for h13 or H10
Fishin is the Mission!
FishnMan's Avatar
Old 12-02-2005, 03:16 PM
Beastmaster's Avatar
Beastmaster is off the scale
Actually, nothing beats HID's - either a retrofit kit with European code reflectors, or Projector HID's.
The issue at hand is the bulb's glass coloration. It actually absorbs effective light and can reduce the amount of light that's visible to the eye, providing the stock bulb and the new bulb are the same wattage.
I've got a work in progress writeup that has a bunch of charts on the bottom. You'll see that color temps (measured in Kelvin) affect the useable light output. In one of the charts, you'll see that higher temp Kelvin HID lamps (10000 Kelvin) put out up to half of the useable light that standard temp bulbs will (4300 Kelvin).
The same principle goes for standard Halogen bulbs. The less coating on the bulb (or no coating on the bulb), the more light you get that you can use.
My recommendation - get yourself higher wattage H13/9008 bulbs, and modify the harness to use a relay setup. Nokya has a 100/80 watt H13/9008 bulb you can use. This site carries them:
http://www.coolbulbs.com/nokya.asp
Duh - I also forgot to add the link to the chart. Go here and scroll to the bottom.
http://24.248.84.138/hummers/headlig...visionplus.htm
M101A2 Trailer
Old 12-02-2005, 03:32 PM
FishnMan's Avatar
Thanks Beast. I appreciate your feedback
Old 12-02-2005, 06:16 PM
tony d tony d is offline
tony d is an unknown quantity at this point
beastmaster I have the higher wattage nokya h-13 bulbs with stock harness and have had no problems .
Old 12-02-2005, 08:04 PM
fourfourto's Avatar
Were you able to get the h10 fog bulbs to match?
Old 12-02-2005, 08:15 PM
Cool. I just keep it as a rule of thumb to try and use a harness with relay on any higher wattage application.
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by tony d:
beastmaster I have the higher wattage nokya h-13 bulbs with stock harness and have had no problems . </div></BLOCKQUOTE>
M101A2 Trailer
Old 12-02-2005, 11:03 PM
WPBGUY WPBGUY is offline
WPBGUY is off the scale
Same Here
Old 12-03-2005, 12:49 AM
automotivelightingusa.com is where I purchased the nokya h-13 stage II bulbs and to get a perfect color match for the h-10 fog lites they recommended using the imtec bulbs also sold by them .
Old 12-03-2005, 01:27 AM
automotivelightingusa.com is where I purchased the nokya h-13 stage II bulbs and to get a perfect color match for the h-10 fog lites they recommended using the imtec bulbs also sold by them . </div></BLOCKQUOTE>
Same Here!
I was their Gunea Pig, just ask joe!
I drove them crazy, but we finally got it!
Old 12-03-2005, 05:32 PM
Just remember, the headlamps are protected by a 10amp fuse. If your voltage drops, as it does in the winter with all the accessories on and you apply the brake lights, that 100 watt bulb may draw over 10 amps, and pop goes the fuse.
Chances of this happening are extremely slim, and it is a split second drop of output due to the PCM regulating the generator, but Murphy says it will happen in the most out of the way location known to man. (You would need a low battery too.)
