11-28-2002, 03:35 AM
Question for you Electricians?
I want to be able to run my Daytime Running Lights at Night.
If I Run a Hot lead from my Headlights to my DRL's with a oneway diode, would I be able to run my DRL's with my headlight?
Would this allow my DRL's to function normally and work with the remote when I lock/unlock with keyless entry?
Thanks,
Ted
03 Yellow H2,Adventure Package,Luxury Package,Sunroof, Wrap-around Grill Guard w/Lts.,Tailight Guards,Roof Lights,Tubular Sidesteps,SMA Tire Rack,Carbon Fiber Dash, Custom Exhaust
Thanks,
Ted
11-28-2002, 12:22 PM
Would this option not be one "just" programmable through the vehicle's computer?
Has any one had experience with any possible programmable options wich can be set on/off by connecting the hand carried computer to the on-board computer?
The Chevy dealer here BTW is still waiting to have his computer upgraded with the H2 software, so he can program key-fob # 1, as this one never worked. Key fob # 2 works okay, but can't use the memory settings of chair/mirror etc. for fob # 1.
Is this H2 software hard to get or what?
12-05-2002, 06:29 PM
Can't use a diode unless you can find one that'll handle the amount of current that the headlights draw. I don't have the fuse chart handy, but I think the headlights have a 20A fuse? I don't think there's a 20A diode. You'll have to go with the relay/toggle switch approach.
I'm going to try to do mine in the next couple of weeks. I'm doing research on the switch to see if I can order the OEM style that they use for the roof lights.
03 Metallic Red H2
02 Ducati 998R
Regards,
David
H2SUT.com
Red metallic, Lux package, Poron backup sensors, throttle body by-pass, Independent dual DVDs, Volant air box, DRL mod, chrome hood handles and latch.
12-06-2002, 11:33 PM
I've been wanting to run the DRL's with the head lights or parking lights, or at least have that option.
I figured I'd splice into the parking lights, run that wire thru a switch, then to a common relay.
From the relay to each DRL. Of course that's after the relay is wired and grounded
This way when the switch is off the DRL's operate as normal. When the switch and parking lights are on, so are the DRL's.
With just the DLR's operating as normal, there shouldn't be any current feeding back to the parking lights.
What you think?
Buddy
12-07-2002, 03:43 AM
Hey Buddy,
That's the right way to do it. I'm still trying to find the part # for the switch that looks like the TC2 and Tow switch. That way, the switch looks OEM and would be mounted in that blank spot below the tow switch.
03 Metallic Red H2
02 Ducati 998R
Regards,
David
H2SUT.com
12-07-2002, 09:36 AM
Hey, you guys make it sound so easy! But where/how do you pass the wiring through firewall/dash to the switch? Speaking of, let us know when you find the OEM looking one. I'll be looking 2.
12-08-2002, 02:50 AM
Ok I am a little confused, the dealer told me that the daytime running lights are still on at night, but like the DRL, only when the vehicle is in drive or reverse. Is this not really the case?
12-08-2002, 12:44 PM
When gets dark the automatic headlamp system will switch from DRL's to the headlights...or if you manually turn the headlights on the DRL's defaults to off.
[img]/infopop/emoticons/icon_smile.gif[/img]
Buddy
12-08-2002, 11:22 PM
I'll try a see if this pic loads.
DRL's and HID headlights on together. The DRL's appear to create a lot of glare at night. The beam is almost like a flashlight on wide beam, only a lot brighter.
Buddy
12-09-2002, 04:18 AM
Hey Buddy,
To get those DRLs to match the color of your HIDs,
try the blue/white tinted bulbs on the DRLs.
BTW, which HID kit did you use? Can you post a pic of the switch?
Regards,
David
H2SUT.com
12-09-2002, 11:09 AM
Which color do the parking light wires have?
Only want to splice the right wire, not he high beam wire, like James Bond always does during a bomb countdown.
12-09-2002, 03:49 PM
Use the hot wire (i.e., not black) from the 'parking light' (yellow lights not head lights). You won't have to worry about high beams.
03 Metallic Red H2
02 Ducati 998R
Regards,
David
H2SUT.com
12-09-2002, 04:09 PM
are acturally amber. The stock bulbs did look pretty yellow though. I am going to try and find some whiter ones for the DRL's.
The HID's are from Breatheless Perf. Although they are single beam only(low beam), they do put a lot of light on the road, better than stock highs.
I spliced into the brown wire at the left turn signal(source wire to active the relay) and run it to terminal #86 of a common relay. Later, when I find the right switch, I'll run thru it and back to the relay.
The remote entry still operates the courtesy lights as stock. The headlamp switch actives the parking lamps and the DRL's together, turn off the parking lamps and you still have the DRL's, one more turn will turn the DRL's off all together. Installing thru a switch will allow you turn off the DRL's while the parking lamps are on.
Buddy
12-09-2002, 04:23 PM
Buddy,
I actually like your switchless idea and activating the DRLs on the parking lights. This way, I don't have to mess with the troubles of running wires through the firewall, mounting the switch etc...
I'm going this route.
03 Metallic Red H2
02 Ducati 998R
Regards,
David
H2SUT.com
01-15-2003, 10:33 AM
After all the rewiring, will the DRL's still function during the day?
And can you turn off the DRL's at night if you wanted just the headlights?
RPV AR Razorback
Grateful and Proud H2 Sunset Metallic Orange owner since July 2002
01-15-2003, 10:38 AM
I am an electrical rookie as well...
I love the look of the DRL's on at night...
Would you be so kind as to jot down what things I need to get to do this to my H2 and the specific steps to take...in very laymans terms...
Any help would be greatly appreciated...
Electrical Dummie from AR...
RPV
01-15-2003, 04:25 PM
Click on this link. Takes about 5 min to do...
http://www.elcova.com/groupee/forums?a=tpc&s=2826088551&f=6706011751&m=687600449 1
Regards,
David
H2SUT.com
Regards,
David
H2SUT.com
01-16-2003, 03:20 AM
NSXTC,
thanks...got a 12 gauge wire, cheap super blue halogen/xenon headlight bulbs and will try to get DRL's on at night this weekend.
RPV
01-17-2003, 10:15 AM
I also changed my bulbs to super cool blue for 19.99/pair and adjusted the beam lower... just as bright but less glare and I like the whitish/blue look!!!
I will do the same for the DRL...is that part # 3157???
Hope to hook up my dig camera soon and post pics.
