Old 09-16-2005, 04:34 PM
flkeysff flkeysff is offline
flkeysff is off the scale
Just got a message from Jim Jackson , President of ARB-USA and he informed me that they have no plans of making a snorkel for our vehicles. That really sucks
Find\'em Hot Leave\'em Wet
Old 09-16-2005, 05:56 PM
And you were really going to drive in deep water anyway.
You should really find out what happens when your fan blades hit water before you get any hot ideas about deep water crossings.
Old 09-16-2005, 09:49 PM
MyxH3 MyxH3 is offline
MyxH3 is off the scale
It already has basically all the snorkel you need. If you you didnt already know the air box is routed through the fender back to the firewall and the the air intake is one of the simulated shock covers if you look you will see the holes in it , the drivers side is the vent for the battery box. if you look closer with the hood up you will see that the air intake is higher than the on board computer, that is mounted on the firewall in the similar location, this makes having a snorkel a mute point.
May the next exit offroad be anywhere you want it to be.
Old 09-16-2005, 11:27 PM
kacyk's Avatar
kacyk kacyk is offline
kacyk is off the scale
Deep water of not it just looks cool. I had one on my 2000 Disco. I crossed a large water puddle (at least 3 inches deep) on my way to Vancouver, WA.
2003 Yellow H2 LUX (Sold)
Old 09-17-2005, 02:24 PM
Crossing deep water is not my only reason for purchasing one, I do like the look it gives and it is another means of cold air intake.
Old 09-17-2005, 09:56 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by MyxH3:
It already has basically all the snorkel you need. If you you didnt already know the air box is routed through the fender back to the firewall and the the air intake is one of the simulated shock covers if you look you will see the holes in it , the drivers side is the vent for the battery box. if you look closer with the hood up you will see that the air intake is higher than the on board computer, that is mounted on the firewall in the similar location, this makes having a snorkel a mute point. </div></BLOCKQUOTE>
The air is taken from the entire fender well. Open the passinger door and look into the fender. The engine gets its air from this space.
