02-23-2005, 06:14 PM
I recently reinstalled my kicker sub box and amp and for some reason my engine is still running when the key is out??? Also my service 4wd light is now on????
02-23-2005, 06:24 PM
It's probably all of the chrome. That, or it's possessed. Did you cut your finger and get virgin blood on the rig?
02-23-2005, 06:33 PM
Any replies that could help would be appreciated. Thanks Eric
02-23-2005, 06:40 PM
Well, did you try the finger cutting?
Go unhook the negative battery cable, let it sit for 14min 37sec and then hook the cable back up and give it a try. Seriously, try undoing the neg to "reset" things. The amount of time is homage to all of the tech lines you call when your VCR, computer, satellite box, etc. is acting up and they tell you to undo the power and let it sit for 15 minutes.
02-23-2005, 06:41 PM
Oh, is it still outside running right now?!?!?!?
02-23-2005, 06:55 PM
Umm.... I am not exactly sure what will happen if you undo the neg. cable with it still running. If it won't quit, I am guessing there is a good fuse to pull in the underhood fuse box to stop it. Then go undo the neg. battery cable.
02-23-2005, 07:33 PM
I'd say pull the fuse or relay for the fuel pump.
Don't disconnect the battery cable while the engine is running. That's a good way to send a voltage spike to your electronics and fry them.
02-23-2005, 07:40 PM
I personally would take it to a dealers before the fuel runs out.
02-23-2005, 07:50 PM
All set.............thanks.
It was a remote wire gone bad off the amp
02-23-2005, 08:42 PM
Reminds me of a '58 Plymouth Fury
02-24-2005, 12:08 AM
Couldn't OnStar have just shut it down?
02-24-2005, 01:32 AM
Couldn't OnStar have just shut it down? </div></BLOCKQUOTE>
You mean BLONDESTAR!!
02-24-2005, 07:12 PM
damn, how much tireshine for you have on those BFG "No Terrains" right now. looks like u could burn all 4 tires right now off the line.
John R. Benda
03\' Yellow Adv- Sold
04\' White H2 Lux - Sold
05\' Yellow Lux - BACK TO YELLOW BABY!!!
04 S55 Benz w/Brabus Tuning
