Old 11-05-2005, 11:42 PM
CslRkH2's Avatar
CslRkH2 CslRkH2 is offline
Do you just remove the screws going in through the plastic into those metal looking supports and pull it off? Do those metal support brackets come out?
CslRkH2's Avatar
Old 11-06-2005, 12:02 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by CslRkH2:
Do you just remove the screws going in through the plastic into those metal looking supports and pull it off? Do those metal support brackets come out? </div></BLOCKQUOTE>
You are talking about the sunroof deflector, right?
If so, yes, you remove the 3 screws and just slide the metal brackets off the roof.
One warning though... the buffetting effect from the wind will drive you nuts.
Why are you wanting to remove it?
Mark
Old 11-06-2005, 12:08 AM
CslRkH2's Avatar
I want to remove it because I have a GOBI Stealth rack & fairing and I want to snug that fairing up against the rack. I can't get the fairing any closer because of the deflector and I'm getting the shadow effect from the lights up there on the back of the fairing.
And I'm bored
Thanks!!
Old 11-06-2005, 12:22 AM
Boredom will do that...lol. Make sure you send us pics of the new rack.
Mark
Old 11-06-2005, 12:25 AM
CslRkH2's Avatar
So is there a sensor up there in the sunroof??? It won't close now after pulling out those metal supports? SH!T
Old 11-06-2005, 12:26 AM
And I'm bored
Thanks!! </div></BLOCKQUOTE>
You can come over and wash my truck(s).
Old 11-06-2005, 12:28 AM
CslRkH2's Avatar
And I'm bored
You can come over and wash my truck(s). </div></BLOCKQUOTE>
That's tomorrow's project for my rig. Ive got bug carnage from my trip back to the midwest. There's bug's in every crevis!
Old 11-06-2005, 01:07 AM
So is there a sensor up there in the sunroof??? It won't close now after pulling out those metal supports? SH!T </div></BLOCKQUOTE>
HUH? Watcha talkin' about?
Mark
Old 11-06-2005, 01:58 AM
Dewi2005's Avatar
Dewi2005 Dewi2005 is offline
Dewi2005 is off the scale
What is the year of your H2?
03 Black Adventurer, Radix Supercharger, Corsa Exhaust, Edelbrock Headers, Air Raid Cold intake.
Old 11-06-2005, 02:13 AM
Dewi2005's Avatar
OK.. looking at the 2003 H2 Service manual, there are no sensors/switches that are connected to the deflector brackets
So, if your RAP (Retained Accessory Power) works.. that is, once you turn off the ignition, all the powered components work until you open a door, or after ~10 minutes, then the next step is to check and see if power is making it to the sunroof motor/switch. If not, then most likely the fuse for the sunroof is blown. If the fuse is ok, then there may be something wrong in the BCM (body control module) which a dealer would have to diagnose.
Hope this helps
Old 11-06-2005, 04:07 AM
CslRkH2's Avatar
Its an '05. The motor was operating and sliding the sunroof closed, but then it catches on something and reverses back to open. I gave it a little help and it closed.
So somehow I f#cked up the lights now too. Created a short somewhere in the harness up on top. Not a good night. What's the saying, if it ain't broke...
