Old 06-29-2005, 12:33 AM
Lost in Space Lost in Space is offline
Lost in Space is off the scale
out how to install.. Anyone else had these? They came with no instructions and cant get the seller to tell me anything.
I think i see how it goes but if im wrong it could break.. Anyone ever seen these go in? Thanks! [img]http://www.pumpthat****.com/h2image/100_0265_S1.jpg[/img]
____________
<img src=http://gfyb.com/your_awesome.gif>
____________
Old 06-29-2005, 02:14 AM
First take a small flat blade srew driver and you will see a oval lookinf screw cover. Well it does not cover a srew. Just slide blade under it and lift them up one on top and bottom . Pull them all the way out and factory handle will come off. Now back allen head screw out to where the 2 duck bill looks tabs close up together. Insert into hole left by factory and apply pressure to handles while you tighten the screws down. Some require more hold down force than others depending on quality. If You do not apply enough force when you screw the allen heads in they will push duck bill looking inserts out and move handle out and it is not held in. will fall in your lap most likely. Really it is very easy just take your time and just keep an eye on what your doing.
TAZ
Old 06-29-2005, 03:45 AM
Thanks! I did get help from a couple people finaly.. Much appreciated..
They're not in yet but I did manage to get 5 stitches in my hand when th allen wrench broke.. Oh well.. Ill use a better tool when my hand heals..
____________
