05-18-2006, 04:34 PM
Slight grinding/binding of front brakes
Im getting a slight binding or grinding of front brakes once in a while mostly during or after rain going slow down a small incline(on the road)just as its comming to a stop..
I thought it might be rust on rotor from sitting overnight after rain.
Im changing my oil this weekend on my brothers lift Ill inspect them then.
05-18-2006, 04:36 PM
Re: Slight grinding/binding of front brakes
I've got some bumping and grinding going on in the back of my Hummah, if you know what I mean. Heh, heh.
05-18-2006, 05:28 PM
You can kinda inspect your rotors by looking thur the wheels and checking for grooves or wear on the rotor. If it looks smooth its probably just rust or possible dirt. Did you do some off roading ? If it continues you might want to have them checked. Not much help, just a couple ideas, See ya bro,,,
05-18-2006, 06:22 PM
My brakes made some seriously freaky noises going down Hells Gate in Moab. Very much like you just described. I think it's normal for the type of pad. But jeez, it was horrendous!
05-18-2006, 07:25 PM
Originally Posted by HummBebe
... pad ...
x2
05-18-2006, 07:31 PM
You might have a little oil soaked into the pads or caliper seepage.
Check for wear on the pads
check rotor condition
check mounting hardware (is it tight?)
let us know what you find.
05-18-2006, 07:32 PM
Originally Posted by H2 Ranger
... the pads ...
Ditto.
05-18-2006, 07:36 PM
I havent did any off roading for a few weeks(and it was light),rotors look good from what I can see in driveway.I did notice after it rained the next day rotors are rusty.Its very light grinding(intermitant) just before it come to a stop the wife was worryed so Ill pull the wheels off on the lift and take a look.If it continues Ill bring it to the dealer.
05-18-2006, 08:10 PM
x2
Lookin' for trouble mister?
05-18-2006, 08:12 PM
There were several witnesses to said grinding noise. Timgco and GenesseMtn.
05-18-2006, 09:36 PM
Not unless you consider padding trouble.
05-18-2006, 10:32 PM
"Grinding" may be a problem, but when they're wet and they make a low sound (much like moving a large piece of furnture with rubber stoppers underneath) when coming to a stop, that sounds normal for this system...
05-18-2006, 11:40 PM
05-21-2006, 10:00 PM
I looked at the brakes on the lift all looks good but it still makes a noise on slow brake .Mostly downhill in rain ?.Not planing on going to the dealer untill roof rails are in unless it gets worse.
I put in mobil one today with a fram tuff gaurd filter,spayed up the bottom a bit with low gloss black(drive shafts were rusty umung other things.There are no lub spots for front end or shafts.No leaks(there was some oil on the crossmember and skid plates from the dealer oil change from filter removel they didnt clean it up nice  )Im doing my own oil changes from now on.(very easy  )I spayed white grease on all hinges and pivit points, emerency brake , cable linkage ect(The dealer said they did it every change(3 changes) they never did anything  )
05-22-2006, 12:02 AM
From a 1996 Chrysler bulletin ( http://www.dodgeram.info/tsb/1996/05-09-96.htm) :
Groan Noise On automatic transmission equipped vehicles, a slight groan may be heard when coming to an abrupt stop or when allowing the vehicle to creep forward slowly with the brakes slightly applied.
What you are probably experiencing is called stick-slip. It is a low frequency vibration cause by the slip between the rotor and the friction material; more pronounced with a wet friction material (pads) when the brakes are lightly applied and the vehicle is rolling slowly.
I notice it when I have the radio turned down and the brakes are wet, usually from driving through some deep puddles. It tends to go away when the pads burn off the moisture; however, if I listen very carefully it will still be there, but not as pronounced.
This is probably what you have, and there is really no fix for it. It does not affect the stopping of the brakes (unless the pads are saturated).
But, not a bad idea to let the dealer check it out to make sure the pads are ok. They are bonded to the pad plate, and one may have lost adherence to the plate, very unlikely, but still possible.
06-07-2006, 03:20 PM
They are still making noise on a slow stop.
Im bringing it in to the dealer on friday.
I will give a update after they look at it.
06-07-2006, 06:11 PM
I make noise grinding my teeth, or my ax
x2
pad
