03-22-2006, 09:51 PM
Phil,
Are these things really worth adding, any noticable difference, worth the money, etc.?
03-25-2006, 03:45 PM
Phil, don't know if U've seen this or not...
03-25-2006, 10:13 PM
Tom, I reinforced my stock trailing arms. It cost $6 or $7 bucks and took about an hour. I used 3/8 or 1/4 (I can't remember now) steel angle and welded them into the stock arm at an angle. It was quick and easy and they are tough as nails. They also provide a great surface to slide on. In the picture it"s kinda hard to see what I did, but hopefully with the description it will make sense.
Before:
03-25-2006, 10:15 PM
After:
04-22-2006, 11:34 PM
Phil, any update on these new ones you tried? I was looking at Hotchkis, but it appears their zerk can get torn off when off road.
04-23-2006, 07:28 AM
I like em! However I think If I were using my H2 offroad I would go with "KEVIN" (no harm intended) I think the possibility of rocks hitting the trailing arms might be a consideration? not to mention the cost savings... But I bought mine for the show circuit, since I use a Landcruiser for offroading.
04-24-2006, 02:04 AM
I just bought a pair of SMA ones on ebay. They are chrome, which I am not crazy about. I will have them done with Line-x soon after Hunting season knocks the chrome off.
04-24-2006, 02:06 AM
BTW, there asre some hotchkis ones on ebay. Must do search on hotchkins thought as seller spelled them wrong.
04-24-2006, 02:09 AM
Here they are if NE1 wants them. You might be able to turn them over so zerk is on top and use 90% grease fitting to reach them. I do not have my rig here to check this though, as Sewell seems to like my rig more than me!
04-24-2006, 02:22 AM
I like KevinB's idea of welding an angle on the trailing arm, so you now have a nice slider, and much more strength to boot!.
www.meatspin.com
04-24-2006, 06:22 AM
X2 Jeep boy.
05-26-2006, 02:57 PM
Re: Phil: on Trailing Arms and pan hard rods
This is the Land Cruiser that you use for off roading?
http://www.elcovaforums.com/forums/s...58&postcount=4
