Old 05-28-2006, 05:27 AM
Bully13's Avatar
Bully13 Bully13 is offline
Default Tubular assist step removal
Ok, I have been searching this forum and the open internet and I can't find this out. I want to remove the step bars but I am afarid that if I unbolt it, I will loose a nut inside the frame. How does this work? Can I just unbolt and not worry? Anybody else with an H3 done this. The H2 is different by the way.
Old 05-28-2006, 09:23 AM
HummerLite's Avatar
HummerLite HummerLite is offline
HummerLite is off the scale
Default Re: Tubular assist step removal
Just unbolt them the nut is held in place on the frame ( you won't lose it )
White H3 5 Speed AdventureLUX, UCP, Gm Sliders, Sunroof, Monsoon, GOBI RACK, Pioneer Avic Z1, Xm, Ipod,Yaesu FT-8800R VHF/UHF, DOI Winch bumper, Warn M8000, Cooper Discoverer's 35's , Boulder Bead Locks ,PCMs For Less tune, K+N Air filter, Rancho 9000's
Old 05-28-2006, 02:45 PM
Mike E's Avatar
Mike E Mike E is offline
Mike E is off the scale
^^What he said^^ also, mine were 15mm nuts. 4 on each side it should only take you 15 mins to remove. Have a friend help you hold them up as you remove the last 2 bolts. It's worth it.
____________________________
