Old 06-03-2006, 06:03 AM
Default Re: Did the torsion today
Originally Posted by Bully13
I'm just gonna say this and I don't care who reads it or whatever the f**k they get out of it.
I'm really glad my wife and I got our Hummers. I don't really care to go down to a shop to have it modified. I think it's more fun to try and do stuff on your own to see what happens.
As for me, I am having a great time and this forum and it's really a lot of fun to be a part of.
So if that makes me stupid - broke - trailer trash - a dyke (lol) - or anything else... so be it.
You damn stupid broke ass trailer trash dyke!!!!
Old 06-06-2006, 01:52 AM
Drew Slothower Drew Slothower is offline
Drew Slothower is off the scale
Question with the Torsion tweek - any left lean noticed?
I've had the bolts turned 2.5 times, and the dealer tried to adjust as well. It seems that the when viewing the truck from the rear, it leans to the left (even with an empty tank of gas).
It doesn't seem that many of you have this problem.. But mine is off about a 1/2 inch on the left. When viewed from the rear, it is noticable!
The dealer says that everything is within spec, but it is still leaning. They even did an alignment (found a slight pull to the left).
Any one have any ideas??
Thanks!
Old 06-06-2006, 02:07 AM
Phil H.'s Avatar
Phil H. Phil H. is offline
Phil H. is on a distinguished road
Mine is lower a full inch on the left in back and .75" in front. I cranked the left torsion bar 2.5 turns and it equalized the front, but the rear still sits .5" lower on the left. Obviously, the leaf pack isn't in spec. On the transporter, maybe they tied it down on the left side and cranked hard on the tiedown.
The dealer was saying the, "It's in spec" garbage with me, too. I ordered a new leaf pack for the rear and will install it myself and will let you know what happens. I plan on cranking the torsion bar back down once the new spring pack is on.
This is a small, easy problem to fix. The H3 is a very nice vehicle!
Old 06-08-2006, 01:36 AM
Thanks Phil - I look forward to hearing your results!
Old 06-08-2006, 02:46 AM
Originally Posted by Anti-BlInG
Agreeeeeeeed, home-made is best. Spray-cans, home depot, and imagination...it works wonders.
right on brother
Old 06-09-2006, 02:51 PM
Phil H.'s Avatar
Oops. It's not as "easy" as I thought. To get the left hand spring hanger bolt out you have to drop the gas tank. Does anyone have access to a service manual? I'd hate to drop it and break something off.
Also, while I was crawling around under the H3, I noticed that while the part number for the two leaf springs are the same, they're also marked with an "L" or "R". On mine, the "R" is on the left and the "L" is on the right. Could someone else take a look at the bottom of their leaf springs and, if you still have the sticker on them, let me know if your "L" and "R" are on the correct sides? Drew, could yours be reversed too?
I live hundreds of miles from a dealer and can't look under new ones.
Thanks!
Old 06-09-2006, 03:48 PM
Phil H.'s Avatar
I just found out that the gas tank skidplate can be dropped without the gas tank coming with it and the tank has a molded clearance groove to remove the spring hanger bolt. Cool! I'll let you know what happened and if it really works that way.
Old 06-09-2006, 04:39 PM
Desert Dan's Avatar
Phil H
I think my rear springs may be reversed also? I'll check the tags and bar code stickers if the are still there.
My H3 leans to the left when looking at it from the rear?
Desert Dan
Jeep TJ Rubicon 2003
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 06-09-2006, 07:22 PM
Phil H.'s Avatar
I dropped the gas tank skidplate and sure enough, there was a clearance groove molded into the tank so the spring bolt could be easily removed. I swapped the springs, which were indeed marked differently. Here's what I found:
Right leaf pack part #15278386 RPN 1126
Left leaf pack part #15278386 RPN 1076
I got everything tightened down, lowered the H3 and voila! It STILL sits 1/2" lower on the left (although that's better than it was). I'm going to wait for the replacement pack I ordered and install it, as long as a left spring shows up.
I'll keep you updated.
Old 06-11-2006, 01:19 AM
Post Part Location
Phil-
I only have one sticker left. Not sure which are the part numbers, but here's all of the identifying info on the sticker. It's on the driver side:
0457945
leafspring R 8386
P137053
01/13/06 @ 09:42:03
What are your front height measurements? Is the suspension off there?
-Drew
Old 06-11-2006, 04:21 AM
Hummer3 Hummer3 is offline
Hummer3 is off the scale
I just checked my leafs and the one marked R is on the left and the L is on the right...
Yellow Lux H3, w/Adventure Pkg, Borla, K&N.
Old 06-12-2006, 05:24 PM
Desert Dan's Avatar
I only have one sticker left too.
Looking from the rear of the H3 the left spring has a sticker thats say "Right"
My torsion bars are marked correctly right and left.
I can't believe that many people wouldn't know right from left?
Could it be the springs are put on the frame when it is upside down??
Desert Dan
1988 Jeep Cherokee
1994 Jeep YJ
Toyota 4x4 Truck(s)
1970 Jeep CJ-5
1962 Willys Wagon
Old 06-15-2006, 09:42 PM
Phil H.'s Avatar
My torsion bars are marked "L" and R", too, and are on the correct sides.
I looked at some new H3s on the trip I just returned from and found that every one I looked at had the leaf springs marked "R" and "L" on the correct sides.
Maybe there are more than a few of us with the springs reversed?
Old 06-16-2006, 04:01 AM
some of the guys must of been looking from the front and some from the rear when they attached them to the frame i guess they finally got everyone to face the frame from behind
Old 06-16-2006, 04:32 AM
Hmmm2's Avatar
Hmmm2 Hmmm2 is offline
Question Re: Did the torsion today
This probably sounds dumb, but can you view the stickers on the leaf springs WITHOUT going under, or without lifting it? Of course, mine is still at the dealer while they TRY to figure out the problem .. but I'm wondering if when the leaf springs were put at the factory, if they either judged left/right while looking from the front back? When I get mine back, I want to try to find my stickers, or, at least take a look while it's still at the dealer and ask them. Does anyone think it makes a difference being in reverse, if they are in reverse?
2008 H2 Graystone Metallic
2006 H3 Black (sold)
previously known as Hmmm3
Old 06-17-2006, 02:57 PM
you gotta get under there part way . just checked mine and they are right on left and left on right maybe some were done while upside down ???????????????????????????????????? who knows
Old 06-17-2006, 08:46 PM
lance-n's Avatar
lance-n lance-n is offline
lance-n is off the scale
my leaf springs are left on right and right on left, too.
i'm just glad they aren't both lefts or rights!!!
White, Adventure, Chrome Billets, Black Leather
1995 White mint OJ mobile (full size Ford Bronco) - sold
2007 Silver Nissan Armada - wifemobile
2005 42' Tiara Sportfisher - Tournament Rigged and 40 knots!
Old 06-21-2006, 07:45 PM
Phil H.'s Avatar
I received my replacement leaf pack today. While the part number matches, the RPN is 1416, which doesn't match anything. Obviously, the RPN isn't a left-right number stamp like I thought. It's probably some production number or something.
GM's parts system shows only one part number for both left and right rear springs. Maybe the left and right stickers are to entertain the assembly line workers and it doesn't matter which side they're installed on (leaf springs, not torsion bars, that is).
I'm going to install this new pack anyway and see what happens.
Old 06-25-2006, 06:27 PM
KJS KJS is offline
KJS is an unknown quantity at this point
I guess I suck at searching, trying to find a thread with a pic or two of exactly where at and which ones to turn! anyone help a newb out w/o being a smatass lol! And its clockwise right too?
Old 06-25-2006, 07:01 PM
StarsnBars's Avatar
StarsnBars is off the scale
The bolts are right under the driver and passenger seat area. You will see the T-bar running down to the cross member from the front. The bolts are located in the cross member If you lay down right at the front -back door pillar you will be right were the bolt is. Jack front end up with floor jack right in the middle. and turn each bolt (clockwise) 2-1/2 turns. I used a sharpie to mark bolt and metal around bolt to keep track of how many turns. Drop jack and go, See ya
