04-11-2006, 04:52 AM
Im not sure if I was asking at this point in time about a train horn to be mounted on a 2004 Hummer H2...If not do you know of a place on the web where I can find out where they are mounting these things? There isnt enough room under the hood..The horn is chrome and has three "Horns" attatched to a base with a seperate compressor tank measuring approx 8" wide by 18" long..The horns measure to the best of my memory about 18" across and 22" long I mean they are a monster. Would appreciate any help you can give.
04-11-2006, 07:01 AM
most mount to the roof rack track, with an adapter plate. and run the hose, and lines through the roof.
03 H2- polished stainless brush gaurds, front and rear. front and rooftop lighting, hard cargo carrier....
04-11-2006, 07:13 PM
I went w/ these. They fit nicely under the hood of the H2.
Train Horns
Semper Fi,
Michael
04-11-2006, 11:58 PM
Train Horns
Darn those are nice.
04-12-2006, 01:02 AM
i wish you could post a mpeg of you driving your rig and scaring some people at the bus stop.
04-27-2006, 07:07 PM
I guess Ill try and look again for space under the hood because these are like the ones that I have... Train Horn I Bought From E-Bay
04-27-2006, 07:10 PM
One last thing has anyone with the train horn experienced a break in the air hose? At the dealer in Hollywood Fla. They said that they dont install them anymore because the air hose breaks and then the compressor runs constantly and burns out...Soooo I thought of using copper tubing like they use on the back of refrigerators for ice machines...
04-27-2006, 11:52 PM
Email this guy and he'll sell you some 1/2 air brake line that will work really well. Also, I do not suggest going w/ a kit from ebay. I went w/ a ViAir 480c Compressor, all 1/2" air line, and a 3 gallon tank along w/ the horns mentioned above. I also suggest going w/ a differnet solenoid to allow better airflow. Good Luck.
FASTBAG90@HOTMAIL.COM
Semper Fi,
Michael
04-30-2006, 11:27 AM
I found these after I installed the Real Wheels horn.
http://www.hornblasters.com/
04-30-2006, 07:45 PM
Search for "Train Horn" and "Air Horn". Dan bought those horns the the trumpets fit under his hood.
He also had some problems with the compressor and trumpets, but got things worked out and they're some loud sum-bishes.
04-30-2006, 09:01 PM
When does RAAARR11 get some? That monster needs some.
04-30-2006, 10:50 PM
05-01-2006, 01:05 AM
LMAO! DO you have this installed? pics installed?
06-08-2006, 04:59 AM
Re: Train Horn For H2
Here is my RealWheels Air Horn installed on the roof rack rails. It was pretty simple to route the air hose under the wiper cowl and up the exterior driver's side pillar trim.
06-08-2006, 06:33 AM
I have the hornblasters kit with the 3 gallon tank I believe. I have a setup on my Dodge Ram also. I have never experienced a hose break problem and I am running 160psi. There is very little room under the H2 to install. The set I run is a 4 horn conductors special and they are big. Here is the set up on mine. If I go offroad and need to remove them 2 bolts and its removed. As far as being worried about the hose breaking and ruining the compressor and draining the battery, just wire it to an on/off switch. Mine is also wired so when the truck is off, there is no power to the compressor, and also an on off switch to disable it when its on if I want.
These puppies are loud, same one as in the hornblasters videos.
10-23-2006, 05:53 AM
I was skimming thru the topics and ran across your post I live across the bay in North Pinellas... Can you tell me what that set up cost and who installed it
10-23-2006, 05:54 PM
Medic, I sent you a pm. I installed the system myself.
