Old 06-13-2006, 04:56 PM
JWSchmidt3 JWSchmidt3 is offline
JWSchmidt3 is an unknown quantity at this point
Default Noisy sunroof
My damn sunroof rattles at just about any speed at just about any opening!! The dealer told me GM knows about it, but they don't have a fix. WTF?!? It seems to be getting worse, any of you DIY'ers have any ideas?? Anyone else have this issue?? TIA
J.W.
2006 yellow H3 - Pro Comp Xtreme package
4" lift, 35's, Lux, etc.
2004 yellow Corvette Z06
2002 black LPE blown TigerShark Z06
http://public.fotki.com/JWSchmidt3/
Old 06-13-2006, 04:58 PM
Hummer Guy's Avatar
Hummer Guy is off the scale
Default Re: Noisy sunroof
What kind of rattle is it? I've heard some bad squeaks when opening before (which just needed some WD40) and the weird air-flow ear popping thing if you put it ALL the way back...is it like the track isn't a tight enough fit?
-Brian
http://www.hummerguy.net
Old 06-13-2006, 05:03 PM
Wisha Haddan H3's Avatar
The dealer's whacked. It may be a known issue, but there IS a fix for it. Sunroofs are designed to be adjustable and rattles can always be tightened up.
... or if it's completely defective, you get a new one
Old 06-13-2006, 05:52 PM
X2 on what kind of rattle. About 5 blocks from the dealership the night I picked mine up I hit a bump (not a big one either) and something broke in the sunroof. If would then rattle whenever you hit a bump and would pop up on the front right corner of the sunroof when you shut the doors. You could sit there and push it up and down. On mine it had something to do with the adjustment screw right there near the front right corner. They put in a temp fix while they waited on the part and no noises since.
Old 06-13-2006, 08:05 PM
Profish Profish is offline
Profish is on a distinguished road
yup...got the rattle also...no fix for it but to close it
Old 06-13-2006, 09:10 PM
wannabeH3's Avatar
the problem is a dangling wire by your light next to the sunroof. put some pressure on it and see if it goes away.. is that it? or is it really your sunroof? i took my to the dealer and they put tape on it for me to hold it down and its all good in the hood now
(with insurance)
Old 06-13-2006, 10:39 PM
It rattles as if it was loose. I first thought it just needed a better wind buffer (like the H2's), until it started doing it at 30 mph, 1/2 way open. Yea, I also have the squeak.
J.W.
Old 06-14-2006, 12:46 AM
I'll be right back...there is a bulletin on this subject. But doggie has to go out before she leaves me a 10 pound surprise.
Old 06-14-2006, 12:58 AM
Subject: Sunroof Rattle Noise (Install Flocking Material) #06-08-67-007 - (05/26/2006)
Models: 2006 HUMMER H3
Condition
Some customers may comment that the sunroof rattles when it is set between the comfort stop and full open position.
The glass may contact the roof rail reinforcement cross bar. Refer to the illustration above.
Correction
Install three pieces (35 mm x 55 mm (1? x 2? in) of Kent BRS tape to the reinforcement bar. Refer to the illustration above.
Old 06-14-2006, 04:21 PM
Dude, thanks for the info. I'll call the dealer and see if they can do this.
J.W.
