Old 06-22-2006, 09:16 PM
rusty rusty is offline
rusty is off the scale
Default manual for e locker?
Any one have the install manual for the eaton elocker? my timid dealer wants to see before commiting to install.
Old 06-22-2006, 09:33 PM
Hummie2's Avatar
Hummie2 Hummie2 is offline
Default Re: manual for e locker?
It won't do much good for the front. It's a generic that mostly applies to rear axle installs. It kind of leave you in the dark as to where to break the wires out of the case at, but a good gearman can figure things out with a little comon sense.
Old 06-22-2006, 09:43 PM
Hummie2's Avatar
Keep the wires from the coil straight as possible, avoid any loops that will later become a kink and cause the wires to break @ the kink (don't ask how I know). Position the shoe on the coil between the webs on the case where it fits the tightest thus keeping any rotational movement in the coil as little as possible.
Here is a pic of where I broke mine out at:
Old 06-23-2006, 05:30 PM
ok, so any problems w/ water intrusion from the wire hole/grommett?
any suggestions to waterproof??
I've been through 32" creeks(called rivers out here) before w/out prob.s, don't want to create any.
Thx
Old 06-27-2006, 10:13 PM
Originally Posted by PhilD
I'm trying to find one, I have it somewhere
But essentially it is no different to installing any other diff, you just have to run a couple of wires for the switch. You'll need new bearings also (which the dealer should have) and that's about it.
Thank you for the manual
If dealer is ok to install, Ill order
Old 06-28-2006, 02:31 AM
Hummie2's Avatar
Thx
No problems so far. Been in for about 2 years and under water some. That rubber grommett fits tight if the correct size hole is drilled through the case. Use some RTV around the outside if you are worried. I believe water would find its way past the axle seals first.
