Old 06-24-2006, 07:52 PM
Default Re: so today was hot...
Originally Posted by evldave
Ah, but now we've found that DRLs are contributing to global warming! This must stop! I'm surprised the uber-liberal EU hasn't caught on to this and stopped their use altogether.
I'm sure DRLs are also the cause of deforestation in the rain forests of the Amazon, genocide in Uganda, and the fall of the Roman Empite. Just haven't found any studies to back those up: yet.
Next time I see Al Gore at the handgun range, I will mention DRLs and see if he goes ape sh*t
Old 06-24-2006, 09:20 PM
Originally Posted by f5fstop
You guys still discussing this subject? If so, just don't look at NHTSA, look at European and Canadian Data, that is where the idea first took fruit. They were the ones who pushed it. NHTSA has looked, but made no decision on requirements; yet.
Problem I found with that discussion is not whether or not DRLs are worth it, it was the idea that $3.00 in fuel per year was a logical reason to have them disabled on a Hummer.
Not a fan of DRLs, but I do see the value in selectable/switchable DRLs for certain driving conditions. I agee with above regarding the discussion about DRLs and saving $3.00 in fuel/year, not worth discussing.
S.
Old 06-26-2006, 06:56 AM
MarK M's Avatar
MarK M MarK M is offline
Is the radiator maybe caked with mud? Have you hosed it out good?
radiator is not caked with mud. first thing I looked at.
MarK M's Avatar
When did you get it, if before August of last year, did the dealer add the extra t/case fluid? If not, might be a good idea to at least have them add the extra fluid.
Axles are synthetic, should be good for a while yet.
got the 3 this past christmas.
Old 06-26-2006, 06:59 AM
MarK M's Avatar
What was your trans temp doing? If the trans gets hot, that will raise your engine temp. PhilD had to install another trans cooler, but since you're stock you shouldn't have that problem.
Just make sure to check that temp before you take the truck in if you can. It'll be good info for the tech and may save him a step or two.
Do the 3's have a trans gauge?
I did hear several people talking about adding an additional trans cooler. Will this help? Of course this is on the H2s.
Old 06-26-2006, 10:45 AM
No gage, but trans temp can be read via a Tech 2. I really doubt any overheating is due to the trans fluid. Could be wrong, but I doubt it. You already have a small cooler. In fact, I believe it is the trans cooler lines that get in the way of the oil filter removal.
Old 06-26-2006, 06:31 PM
MarK M's Avatar
Thanks F5, I'll take the 3 in to the dealer and have them do the vag thing...
Old 06-27-2006, 08:41 PM
Wisha Haddan H3's Avatar
Don't you have to go to an FJ dealership for that kind of service?
