Old 06-30-2006, 07:22 PM
Hummer23's Avatar
Hummer23 Hummer23 is offline
Hummer23 is off the scale
Default question about the factory brushguard install.
I bought a used factory brush guard off E-bay i plan to install. It only had some light scratches. Anyway it was used and came with no instructions or anything. I am making my own contact pads. I have determined I have the later model with the easily removable tow hooks.
Is that all you do is secure oem guard through the tow hooks and tighten down. I believe that is it, but I have no local dealer to refer to, so i figured someone on here would know
Montana "The Last Best Place"
H3 Adventure!
Old 07-01-2006, 01:00 PM
Vandakeg Vandakeg is offline
Vandakeg is off the scale
Default Re: question about the factory brushguard install.
I bought an OEM brushguard from TimGCo on the forums here, and literally had it installed in 30 mins (with a helper!).
I didn't have the rubber 'bumpers' either, so I used some Loctite Instant Gasket. I don't know if I should've used it or not, it's just what I had laying around, and it seems to have worked fine (it's been on for 3 months w/o problems).
Old 07-01-2006, 01:49 PM
Mike E's Avatar
Mike E Mike E is offline
Mike E is off the scale
That is it! Just unbolt your d-rings, remove the 2 bolts holding the brackets on and bolt the brush guard on. Don't forget that little 10mm bolt in the center of the bracket. It's super easy. You might want to have someone with you to hold the brush guard in place while you put the bolts back in. That makes the job a lot easier. It took me 15 mins from start to finish.
____________________________
Old 07-01-2006, 04:34 PM
Hummer23's Avatar
Thanks guys, That is what I thought I just wanted to make sure, i am going to put it on this afternoon.
H3 Adventure!
Old 07-02-2006, 01:07 AM
I've taken mine off/on a couple times. Piece of cake.
